Question about Brother SX-4000 Typewriter
Cannot margin release ]3] to extend into hot aone
I have done this many times. what am I missing
  • Anonymous Jan 23, 2009
    Cannot change left or right margin on sx4000. please help i am filling out tax forms and have already ruined 8 forms and have 2 left.
Sx4000 cannot change the margins left or right
Posted on Jan 23, 2009
    Scholar:
  • 183 Answers
HOLD DOWN THE "ALT" KEY THEN HIT THE 3 KEY THEN USE THE BACK SPACE OR SPACEBAR TO REPOSITION THE PRINTHEAD. THIS WILL ALLOW YOU TO MOVE PAST THE MARGIN ONE TIME. IF YOU WANT THE MARGIN SET IN A DIFFERENT POSITION - MOVE THE PRINTHEAD TO WHERE YOU WANT THE MARGIN SET, HOLD DOWN THE ALT KEY AND PUSH THE 4(L MAR) OR 5 (R MAR)
Posted on Dec 20, 2008
3.0l engine. OK when cold. When it warms up, why does it miss and flatten out under load?
Sorry to say, If you had the work done at a shop. shops just don't give your new, remanned,or used motor or transmission the best shot at living a long or extended life. Unless new. But ts is still marginal.
Jun 30, 2015 | 1990 Nissan Pathfinder
How do I release the right margin on the typewriter?
Look above the 3 key, you will see M REL that stands for Margin RELease. Move to the margin you want to change and wail holding the ALT key and press 3. Repossition the print head by using the BACKSPACE or SPACE BAR then again hold ALT as you select the new Left Margin or Right Margin (4=L MAR or 5=R MAR)
Nov 10, 2011 | Brother ML-300 Typewriter
Reset margins
Go to the R. margin, press but don't hold the mar rel key, space to desired location, press R MAR, DONE.
DickyO
May 27, 2010 | Nakajima AE-710 Typewriter
Setting nargins
The keys used for margin control on the brothers is the ALT key just to the left of the space bar, and the #3,4,& 5 keys.
To move outside the present margin to the left, backspace to the left margin. Press the ALT and '3' keys at the same time to bypass the margin. Back space past the margin to the point where the margin is to be set. At the point you want the new left margin, press the ALT and '4' keys at the same time to set the new left margin.
To move outside the present margin to the right, spacebar over to the right margin. Press the ALT and '3' keys at the same time to bypass the margin. Then spacebar over to the point where the new right margin is to be set. Press the ALT and '5' keys at the same time to set the new right margin.
The basics are that the ALT +3 releases margins, ALT +4 sets the left margin at the point of the carrier, ALT + 5 sets the right margin at the point of the carrier.
Hope this helps.
Mar 15, 2010 | Brother ML-300 Typewriter
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
How do I reset the right margin for my Brother ML300
Hi:
Most of these small portable typewriters have dual function keys. You need to find the keytop that has Margin Release on it. It might say Mar Rel. If this in in a color that is different then what ever else is on the key then this is a daul function key. What this means is that you also have to look for a code or mode key. Once you find that hold that key down while pressing the Mar Rel key once. Then release both keys and use the backspace key to back up through where your left margin is currently set. Once you have done that you can reset the left margin at that point by findind and pressing the Left Margin key. Note that the left margin key might also be a dual function key.
You can extend the right margin by spacing to it and then doing the same procedure above , but this time release the right margin and space throught it and then reset it where you want it.
Good Luck
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
Jan 05, 2010 | Brother ML-300 Typewriter
Swintec 640 margin release
If it is the left margin, you touch the carriage return button to find the current position of the left margin, then touch the mar release button and backspace to the new left margin location, then depress the left mar key. You should here a beep. You are done.
Jul 22, 2009 | Swintec 7040 Typewriter
How do I reset the margins for bigger paper?
Hi:
Good Luck
Andrew
Jun 26, 2009 | Brother ML-300 Typewriter
Help with Typewriter
hold down the code key and press the margin release, to set margin, just hold code release margin, space over to where you want it and then press Margin set, left or right.
Jun 05, 2007 | Brother GX-6750 Typewriter
Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
Mar 09, 2007 | Brother GX-6750 Typewriter
Brother SX-4000 Typewriter Logo
110 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
