Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv27fv300 changes channels by itself?
Crazy tv. changes channels by itself, locks out any other operation. other than that, a nice tv. any suggestions? thanks, dave
    Novelist:
    Champion:
  • 275 Answers
Guys, Just check and see if any of the Program / Channel + or - buttons at the Front panel are Ok? If any one of them has been accidently pressed too hard, then it locks the button in a permanent ON position, and channels keep changing.
Posted on Apr 04, 2007
Try unplugging your TV for 8 hours and it comes back to normal. At least it did with mine.
How to tune channel when channels are locked?
The Sony KV-36HS510 has an Auto Setup function for the channels.
1 Press POWER to turn on the TV.
2 Press TV FUNCTION on the remote control.
3 To continue running Auto Setup, press CH+. To exit Auto Setup,
press CH-.
Auto Setup automatically creates a list of receivable channels. When
finished, the lowest numbered channel is displayed.
To reset the TV to factory settings
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
Apr 14, 2016 | Sony FD Trinitron WEGA KV-36HS510 36" TV
The TV goes crazy and changes channels by itself!
try to interrupt it by pushing the channel in the opposite direction or tapping the channel up/down button with your finger.
Mar 05, 2015 | Televison & Video
Changes channel by its self it goes crazy
You have ONE of two possibilities....on the Front panel buttons, you MIGHT have a stuck button or leaky button....
I suspect that if ALL it does is change channels...it would be a channel UP or DOWN button stuck....yes, it can fire up the tv too....But it will dedicate itself to doing only ONE function.
IF you have multiple operations, like changing channels, menu appearing, volume changing....then the MOST likely problem is actually the microprocessor causing the problem....BUT it is STILL possible to have SEVERAL buttons stuck....rare, but possible.
And unfortunately unplugging it won't even help in any of these possibilities....
You have to start with pressing each and every button one at a time and see if the problem stops afterwards....
IF it doesn't, then the next step is to measure the resistance across each button....they should read Infinite ohms.
If any measure lower, the button should be removed and see if the TV acts normally...
IF the buttons are located on a separate board with a plug that can be disconnected, you can just disconnect that while it's acting up and see if the problem disappears.....
If it still misbehaves after this, you NEED to get it to a TV tech for further analysis with a scope.....
Jul 08, 2009 | LG 47 in. Flat-Panel LCD HDTV
Vcr does not run
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
Oct 25, 2008 | Sony SLV-685HF VHS VCR
TV TURNS ON BY IT SELF AND CHANGES CHANNELS AND FPA LOCK IS ON
the problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
Oct 22, 2008 | RCA 20F420T 20" TV
Stuck on channel 2, "No Signal" and snow
Two things may be at play here. The tv might be only programmed for reception on channel 2 and will need to be re programmed to receive other channels.
Also try some basic troubleshooting on the remotes. Start with the remote that came with the tv. Replace the batteries try the "MENU" button. If you can get into the menu try to "autoprogram" the TV
May 01, 2008 | Sony KV-36FS100 36" TV
KV27FV300 PIP
I think that is dried solder try to re solder the video chroma ic or change the capacitor 250v/10uf near the FBT (flyback)section
Apr 27, 2008 | Sony FD Trinitron WEGA KV-27FV300 27" TV
Kenwood VR-405
more info would be nice. If you're using optical, make sure its securely in both the tv and your vr-405 receiver. I have owned the vr-405 since 2000 and i just purchased a sony 32xbr6. HDMI into the TV, optical out to the receiver, it sounds amazing!
Dec 01, 2007 | Kenwood VR-405 Receiver
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Lack key appear on my flat screen
Do you use the remote control or buttons on the tv itself? Many TVs have a child lock feature that will prevent operating the TV without the remote control. If you use the remote control you should be able to change chanels, and to disable the child lock from the menu.
Mar 09, 2007 | Sony 21" Trinitron P202 Flat Screen...
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
427 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
