FixYa.com
Tags:
Centrios Portable CD Player Carrying Case Personal CD Player
The cd door is stuck - i cant open the door or...
By Phoebe - usenet poster
the cd door is stuck - i cant open the door or close it, help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 26, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
put a fish finger in and rub the contacts does the trick
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 08, 2005
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
1. Make sure the drawer-loading belt is still tight and elastic. If not, it can be replaced with a belt obtained from an electronic-parts supplier. The replacement should be of equal or slightly greater thickness and should fit snugly but not so tightly that it strains the motor.
2. Check for broken or loose gears and have them replaced.
3. Check for obvious sources of contamination such as pet hair or foreign objects that are preventing smooth operation of moving parts. Small children have a habit of inserting items into CD players.
4. Use electronics-grade contact cleaner to clean the door-position contacts.
This Problem Also Relates To: Audiovox (DBCE600MP) Personal CD Player GPX A329 Personal CD Player GPX C3960 Personal CD Player GPX CDP3305 Personal CD Player GPX CDPW8806 Personal CD Player GPX MP3 Portable CD Player and Radio Personal CD Player GPX C-3949BI2 Personal CD Player
Can you Help with these Personal CD Players problems?
Personal CD Players
dvd player
i have the wd810 and i have... Answer This...
Personal CD Players
audio drivers
i dont have eny driver Answer This...
Personal CD Players
Ipod Touch
I have an ipod touch that i... Answer This...
Personal CD Players
I cant turn on my cd stereo
just stop it and no work any... Answer This...
Centrios Portable CD Player Carrying Case...
Portable cd player can't read...
My daughter has a Philips... Answer This...
Repair Service
Find Personal CD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
