Question about Cook's Essentials Cooks Essentials Arome 10-cup Coffee Maker
Setting the clock on my coffee maker
I am able to set the timer on my coffee maker by holding down the clock button then releasing it. However, I have been unable to set the clock itself.
After turning the coffee maker on press and hold down the timer button until flashing; then press the hour and minute buttons to set the clock.
Posted on Dec 20, 2008
Not filling to capacity
In most cases there is a digital timer on the machine or a manual timer. The timer should be located behind the panel behind where the container sits below the funnel. If it is a manual timer you can simpley turn it up in small increments. If it is a digital timer you will need to unplug the machine, find the little dipswitch on the board the will read set on one side and lock on another. Set the switch to set, plug the machine is and hold down the brew button til you hear 3 clicks. After the third release the button and let it fill to about 2/3rds of the way up and turn it off. If it is still not correct you can repeat this by turning it back on and holding down the brew switch but allow it to go either higher or lower of the previous level til correct. Hope this helps.
WWW.MidstateBeverage.com
Feb 09, 2011 | Bloomfield 8572 Coffee Maker
I have Mr Coffee APX33; I do not know how to set the coffeemaker to turn on automatically. I do not have the manual. Hope you can help. Thanks! Larry
First you have to make sure to set the clock for the correct current time:
Press down and hold the SET button. Then alternately press the UP and DOWN buttons (indicated by arrows), until you reach the current time, then release the SET button. (there is a PM indicator on screen but not an AM indicator - if you don't see the PM you are at AM)
To set the time for the brew to start in the future:
Press and release the MODE button once and the Delay Brew Clock picture will start flashing on the screen.
While the Clock picture is flashing - hold down the SET button while you use the UP and DOWN arrow buttons to set the desired brew time (you can hold down an arrow button to get there faster). Release the SET button and now that brew time is programmed. (After a few seconds the clock picture will disappear but the future brew time is programmed.)
To activate the delayed brew:
Press and release the MODE button once. The Clock picture will be flashing and the time shown will be the time that you previously set for the future brew). While the Clock picture is flashing - press and release the BREW button. The Clock picture will remain on steady. The BREW light will not come on until the time in the future that you have programmed.
Pretty confusing - but it does work. Just remember that if you see the Clock picture on steady - the machine will come on at the time you have set in.
If you want to use the machine earlier - while the Clock picture is steady - you just press the BREW button and it will brew.
If the Clock picture is steady but you want to cancel the automatic future brew - just press the BREW button twice. (This turns it on and then off and cancels the future brew).
I can send a copy of the manual if you like. Lennyg678@aol
Sep 17, 2010 | Mr. Coffee APX33 Coffee Maker
How I can Programing the coffee Maker?
If it has a newer timer look for a circuit board usually in the rear after taking off panel and looking for a small dip switch,usually white.Put position to set,turn on red on/off switch ,hold down brew button until you here 3 clicks then release to start brew cycle.When close to proper brew level turn of red on/off switch to lock in.Put dip switch on board then to lock position.
May 20, 2010 | Bunn CWTF 15-APS Coffee Maker
How to program dcf212t
If you're talking about the timer, first make sure your time is set correctly by holding down the "set clock" button until the proper time appears. make sure it's correct for am or PM. Then hold down the "set timer" button until the time appears that you want it to turn on. Again, ensure it's AM or PM. Then push the "on auto" button twice, so the light is green. You're done.
Oct 28, 2009 | DeLonghi DCF212T
How do I set the time on cuisinart coffee maker model cbc-00? Regular time 12 hour intervals Thank You
Set the function knob to CLOCK
Press and hold the HR button for a few seconds if the clock display time is not flashing
Once display time is flashing:
Press and release the HR button a few times for it to advance - it will say "PM" on the display if it is set for PM
Press and release the MIN button to set the mins
Sep 12, 2009 | Cuisinart DCC-1200 Coffee Maker
I need an instruction booklet to set the timer for the coffee.
Go to Hamilton Beach dot com, pull down customer suppot menu, click on use and care guides, type in product and model number, click send and your manual will load. Print it out so you have it. Setting the timer is a piece of cake, Hold down the program button until the clock flashes. While still holding the program button down, set the timer for whatever time you want the pot to perk. Let go of the program button. To check if the timer is set right right, puch the prigram button just long enough to see what time it is set for. If it's right, prepare the pot the night before, push the program button to set and forget about it. It will perk at the time you set every morning. Katherine
Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Coffee maker timer does not keep the heat plate on after 10 mins.
I was able to fix my little problem. I unplugged my coffe maker and waited 'bout 10 mins for the whole thing to shut down. Once the clock shut off, I reset the time. Secondly, I pressed the on/off button and held it in for 2 seconds until the red light started flashing. I set H to 1 and M to 59(I have never seen this before). anyhoo, afterthat, I set the timer to the exact time I wanted to smell my freshly brewed coffee. This morning, the red light seemed to stay on and kept my coffee nice and hot.
Nov 25, 2008 | Braun AromaDeluxe KF 580 Coffee Maker
Melitta mill and brew 10 cup grinder/maker
  1. Press and hold the TIME button for 2 seconds. The green TIME light will come on and display will read 12:00. The unit is now in the timer programming mode.
  2. Press "HR" and "MIN" button to program start time. Small dot in upper left corrner signifies clock is programmed for A.M. No dot in upper left corner means clock is programmed for PM.
  3. The Timer Display and LED light will flash 5 times to indicate that timer is now set. Press and release the TIME button. The green TIME light will come on.
Sep 06, 2008 | Coffee Makers & Espresso Machines
Setting the Time
First, turn the Function Knob (bottom-left of the Control Panel) to “Clock”.
Hours: Press and hold the “HR” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press(pulse) the button to advance one digit at a time.
Note: When the number passes 12, the PM light will be displayed on the LCD.
Minutes: Press and hold the “MIN” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press (pulse) the button to advance one digit at a time.
To finish setting time, turn the Function to any setting other than "Clock", or simply wait until the numbers stop blinking.
Jul 26, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
1,227 people viewed this question
Top Cook's Essentials Coffee Makers & Espresso Machines Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Robert Plante
Are you a Cook's Essentials Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
