Question about Refrigerators
My wine cooler is too warm - Refrigerators
    Scholar:
  • 111 Answers
Wine coolers aren't designed to anywhere near as cold as a regular refrigerator. How warm/cold is it running? Red and white wines have different temperature settings too
Posted on Dec 19, 2008
CWR531SZ EDGE STAR WINE COOLER FOGS
professionally installed or diy if pro call them back sounds like cooler is cold room to warm
Apr 12, 2013 | EdgeStar CWR531SZ - 53 Bottle Built-In...
How do I know whether a thermoelectric cooling system is better for me than a compressor?
This depends on several factors: how much wine you keep on hand, where you will be putting the cooler (cool/warm room in the house) and if you are buying a freestanding cooler/built-in. If you never have more than two cases, plan on keeping the cooler somewhere it won't get too warm and you want a freestanding cooler, you should look into purchasing a thermoelectric cooling system.
Jul 31, 2012 | Furniture
I have a GE ZDB24A under counter wine cooler that continues to frost up regardless of the setting. I have a second cooler downstairs which stays clean - no frost. What do I need to do?
check the door seal, make sure that its not ripped or dirty. Its possible that moisture is entering the wine cooler thru the door gasket. Frost is normally the result of warm moisture mixing with cold air. The door gasket should be the problem. if you thoroughly examine and its fine, let me know and we'll go to the next step.
Feb 06, 2011 | GE ZDB24A Wine Cooler
Stopped cooling compressor warm to touch
Feel the condenser on the side to if its warm top to bottom. If It's warm good if it's cool bad it's out of gas. That means leak in the system. If there is a leak, a new box may be cheaper than to fix it. If it is warm check the evaporator and evaporator fan. Make sure the fan is working and the evap-coil is not frozen.
I hope this helps.
Aug 23, 2010 | Haier BC112G Wine Cooler
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
Does not cool the wine,back panel is warm and unit is making a no
If your condensor fan is running and the compressor is running then you will need a tech to look at the sealed system for you.
May 26, 2009 | U-Line 15WC Wine Cooler
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
