Question about Black & Decker BDHF600T Heater
Space heater doesn't go on
Our space heater doesn't turn on even though the red light on top is lit.  We've turned up the desired temp way above what the unit states is the room temp, to no avail.  We feel like it may have to do with the peg on the bottom of the unit needing to be reset or calibrated, but aren't sure.  We have it on a flat surface.
  • Anonymous Jan 18, 2009
    I have exactly the same problem.
What is the error 128R9, master temp 400
Let's get more info!
Take off the front panel of the heater... If you have space to kneel down and look under the display to the back of the circuit board then front panel us all you need to remove for now, if it's too difficult to see or if you have no space then the top panel would need to be loosened by removing the wing nuts on each corner. If you do loosen the top panek be careful when lifting it as the wires are still connected!
Turn heater on and tgen check the back of the board to see which tiny red lights are on , take note of which are on and what abbreviation is next to the illuminated light.
this will tell you which area of the heater the issue is then repost with that info
Feb 13, 2015 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
I have a Comfort Zone cz20110 and I need help. The heater will turn on and blow out heat, but the display screen is blank. It was not blank when we first plugged it in however and I know there's a way...
i have a digital quartz infrared heater comfort zone cz20110. does the fan keep running all the time and when it reaches the temp to your room why doesn't it it shut off.
Jan 02, 2013 | Heating & Cooling
Water not hot even thermostate turned to high. The pilot light is on. Shoulder I be able to visualise the burner actually firing.,or hear it firing. I can see the pilot light clearly. Please help
If you have cold water now, you should hear the unit fire up and run while heating water. Proceedure would be; pilot is lit with thermostat at pilot setting. Once pilot is lit, you turn up to desired temp setting and you should hear the heater running. Depending on lighting, you should be able to see it slightly brighter and may flicker some while heating.
Apr 25, 2011 | Rheem Water Heaters
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I have a Martin ventless gas log fireplace heater and can't get the pilot light to light. In the past, I've had problems keeping it lit, so I've kept pilot lit all year. The other day I successfully used...
You should the value there should be a pilot ajustment screw
some times it is hidden under another screw but should be close to where the pilot light line hooks to the gas value
Dec 12, 2009 | Desa International Unvented Gas Space...
Need opearation manual for enviro home heater
I purchased two of these heaters from Home Depot, and neither one will heat up at all. If I kept the boxes, I would be returning them to the store. I think they are junk,,,,
Mar 16, 2009 | Heating & Cooling
Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Jan 20, 2009 | Water Heaters
Black & Decker BDHF600T Heater Logo
67 people viewed this question
Top Black & Decker Heating & Cooling Experts
Paul Carew
Dan Apthorp
Shimon David
Shimon David
Are you a Black & Decker Heating and Cooling Expert? Answer questions, earn points and help others
