Question about Compaq Keyboard
Compaq R4000 - Spacebar needs pressure
My Compaq R4000 spacebar used to move with a slight thumb tap. Now it needs a forceful push to respond. No cat, no spillage. Any ideas? It is just over 3 years in use and only by myself.
    Novelist:
  • 151 Answers
I) try connecting another keyboard( if you have any spare) if it working ok .... then there is problem with ur keyboard(>3 years)
Posted on Dec 31, 2008
Why doesn't space bar move the carriage?
you need more tension on the draw band usually done with a screw and worm gear arrangement on the left side under the carriage
Aug 23, 2015 | Office Equipment & Supplies
(Remington Streamliner) the space bar automatically tabs instead of moving one space forward. How do I fix this?
This can mean that the spacebar is not being tapped hard enough, the spacebar is sticky, the escapement is sticky, or the spacebar linkage needs adjusted. If the letters do not cause this, then the escapement being sticky is less of a concern. Sometimes the touch on the spacebar is right on the point where the escapement mechanism just barely escapes and doesn't lock in. First try tapping the spacebar more firmly to see if this helps.
Aug 14, 2013 | Office Equipment & Supplies
Screen to thin on my laptop computer
Really?
Well get that cat back over there, and tell it to fix it, Wolfman! lol!
(Freakin' kitty, come back here, and fix my laptop screen, or no TV for you tonight! NO,....I'm NOT kiddin'! You can't watch Shrek)
Laptop running, Windows loaded, press, and hold down on the Fn key. Now tap the Spacebar.
Keep tapping until the screen size is correct.
(Cat must have stepped on the Spacebar, and Fn key at the same time)
Regards,
joecoolvette
Jun 23, 2012 | Toshiba Computers & Internet
Xps 15 spacebar not working properly
there might be some junk underneath the keyboard turn off computer
open the screen and lift the computer so that edge of keyboard is on table
GENTLY tap the computer and watch to see if something comes out
if not then you will need to clean keyboard or get a new one
May 17, 2012 | Dell Studio XPS 15 Notebook
I took my spacebar off to clean it and i dont know how to put it back on?
There is a rubber part that is designed to spring up when you release the space bar - this is the contacts that is the electrical push button. At each end the metal bar is hooked to the plastic (the long space bar key). There may be a couple springs found as well - they should seat on the base. Connect all pieces and place the space bar key over the area where it aligns to the keyboard and snap it place with a slight force.
Nov 23, 2010 | Compaq Keyboard
Spacebar not responding on Toshiba laptop Satellite
Since the spacebar is the most used key on the keyboard, it is likely a hardware failure of the spacebar itself. Replacement keyboards can be found on EBay and normally run about $20
Jul 05, 2009 | Toshiba Satellite M45-S331 Notebook
Touchpad malfunction
Do you mean when you just tap the pad w/ ur finger? if so this is a setting that can be turned on and off. Have you or anyone been pilfering through the settings?
  `Nbryson
May 30, 2009 | HP Compaq Presario R4000 Notebook
The spacebar doesn't work consistantly unless ''pounded''
The spacebar is the most often used switch on your keyboard, so, yes, it's from overuse, but also from
the fact that it is the longest key on your keyboard and the closest to the edge, all of this combining to
make it the dirtiest key on the board.
So, get a keyboard cleaning kit, either professional or DIY which would consist of the following, cotton
swabs, compressed air, and maybe a toothbrush and realize that all the stuff that accumulates under
your keyboard's space key makes it harder to depress to the point where contact is made.
Apr 11, 2009 | Computers & Internet
Media.center.keyboard.spacebar.does.not.work.after.cleaning
i have already posted the solution to my problem.....but i will tell you in more specifics what transpired.........after removing my spacebar.....i used electric pre-shave (an alcohol based solutions with a slight amount of lubrication).......with a few drops of that and a q-tip i cleaned the black tarry mass that had accumulated underneath the space bar most likely from spilled pop,coffee,pancake syrup,cat hairs,and only god knows what else...........after replacing it it worked fine mechanically and physically but did not work on the screen......after a day or two it started working .....i guess the alcohol needed to dry out .....i did put two drops down the tube that had a pad at the bottom (contacts underneath it ).........everything working better than new now .......thanks for being here to help.........
Feb 18, 2009 | Sony VAIO RA710G...
Spacebar-quit-working-after-cleaning-the-gunk-underneath-----now-it-does-not-work-at-all? it-is-a-vaio-keyboard-with-media-center-controls-at-the-top...........
Have you tried applying pressure gently until it snaps back in place? That could be the issue, is that the spacebar unsnapped itself when you were cleaning it. If you were using compressed air (canned air) then you may have blown something underneath it and it jammed itself in there. Trying turning the keyboard upside down and gently tapping it on a hard surface to see if anything else comes out.
Feb 18, 2009 | Logitech 967437-0403 Keyboard
Compaq Keyboard Logo
107 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
