Question about Jenn-Air JMC7000 Microwave Oven
Jenn Air blt in microwave doesn't heat -Otherwise works fine!!
Jenn Air model JMC7000 ADB. Everthing works and looks normal except it doesn't heat the contents. It does make a slight buzzing sound when it "pretends" to be cooking that it didn't make before. It also emmits an electrical smell if you continue to allow it to run.
Unit is approximately 8 years old and is otherwise in good condition.
Are there other MW ovens that can just replace this unit rather than fix it?
Thanks for the help
  • jsfigore Jan 06, 2009
    I just posted this same problem---unit is also 8 years old. Considering the cost of the built in oven/microwave combination, I woudl like to know which unit would fit in same footprint and be a replacement for the JMC7000. I called service and they are coming out in a few days so I would like this info to know what to do based on what service finds.
  • 3 Answers
Replace the door switch I ordered mine at www.repairclinic.com
Posted on Feb 06, 2009
Looking for an exact size replacement for Jenn Air JMC7000
it looks like the Magic Chef MCD1611 is the same size
Jun 16, 2011 | Jenn-Air JMC7000 Microwave Oven
Acts like working, but no heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dgyj57we
Apr 21, 2010 | Jenn-Air JMC7000 Microwave Oven
Jenn Air Microwave M169W will run but not heat
heatman101
zcvzcv
Jan 28, 2009 | Jenn-Air JMC7000 Microwave Oven
Need to replace JMC7000 Microwave
Yours will likely have a bad high voltage diode, transformer or magnetron, all of which are covered under the extended parts warranty for five years from the date of purchase!
All you have to pay is labor, unless it's less than the two-year full warranty, then there's no charge.
That's a really great warranty!
It's on the back page of the owner's manual.
If you opt for replacement, Jenn-Air Customer Care can tell you which model would be a "drop-in" replacement.
Jan 06, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn Air Microwave won't cook
I had the same problem with mine wich is the same built in Jenn Air jmc7000 after using an ohm meter to check some of the switches I discovered the door swith was bad replace it for about 5 dollars and it works as good as new...Good Luck
Jan 04, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Dec 19, 2008 | Jenn-Air JMC7000 Microwave Oven
No power on Jenn-Air JMC 7000 ADB Microwave
It's either the fuse or the thermostat on the magnetron.
You can download the service manual here.
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 29, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Jenn-air microwave JMC 7000 ADB has no power
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
427 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
