Question about Bunn Pour-O-Matic VPR
The heater no longer keeps the water hot. Warmer still works
Suddenly, with company coming for Christmas, of course, the unit decided to quit heating the water to brew the coffee. The warmer still works. Guess it is the heater or the thermostat.
  • kents229 Dec 19, 2008
    Novelist:
  • 125 Answers
Hi, if your unit is a VPR, there are only 3 things that could cause the tank heater to not work, 4 if you count wire burn off. 1: your heating element has failed, blown open, and has no resistance ( measured by a meter device) 2: the thermostat has failed, usually they boil though, also just a simple switch, open or closed by the adjustment knob, measurable by a resistance meter also. 3: the hi limit has opened due to the tempurature in the tank getting too high, usually caused by evaperation of the water, and the level drops too low, from not pouring a pot of water in at least every other day. This also is a heat activated switch, that is closed all the time at room temp, when measured with a resistance meter. Your heat circuit MAY have an on/off switch too, but as long as this is on, that heat circuit runs 24/7. I would not advise it permanent, but you could jumper/bypass the hi limit and/or the thermostat to test, but if you do not know how to test it, at least take it to a shop and let them check it for you.You can go to www.bunnomatic.com or contact technical service, depending if you have a commercial unit or not.
Posted on Jan 04, 2009
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
Truck will only heat for a minute then quits
make sure hot water is flowing thru the heater core by feeling both hoses, in and out, both should be hot. if not, maybe the valve is not opening to allow the water to flow. If both hoses are hot then maybe the heater valves are not working and you are just bringing in cold outside air instead of the air flowing thru the heater core and providing heater air. Could also be a sensor in the heater that thinks it is a lot warmer than it really is.
Feb 17, 2015 | Cars & Trucks
Household steamer not heating at all
Well, first thing, just hook up service water and turn it on so the water heats up. Leave it long enough for water to get hot. If water doesn't get hot like should, then heating unit is malfunctioning. If it is getting hot after a while, you pull the handle trigger and water comes out, you have to wait long enough for the hot water to get to the head/trigger for it to go into the nozzles. If it was working ok before, and you were waiting for the water to heat, then then it should be working fine. Tell me what is happening if you wait for water to heat and get to the nozzles. I'm right here at my computer and we can get this thing going if the heater unit is good. Regards, Rigger.
Oct 07, 2014 | Heating & Cooling
I just renter a house with a Rinnai R94LS water heater. The house and heater are 3 years old. 50-70% of the time I get a shower, the hot water suddenly stops after just 5-10 minutes and goes completely...
Its a tankless heater. It will heat water as long as it senses a large enough flow of water. Either the flow sensor is bad, or not sensitive enough, or you are using less water than it is set to work at. Try keeping a large flow running. Instead of a trickle, shut it off entirely.
Apr 09, 2017 | Heating & Cooling
Heating but no hot water
Check for crossover/ bad check valve or bad single-handle faucet cartridge
http://waterheatertimer.org/Crossover.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 26, 2013 | Water Heaters
My rheem (20) instatanious gas hot water heater takes so much longer to heat up in the colder months wasting too much water and also losing water pressure when it finally does get hot.In the warmer months...
2 possible things: tempering tank and crossover.
http://waterheatertimer.org/Tempering-tank.html
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | Rheem Water Heaters
Our 20 yr old water heater periodically gives much less hot water while taking a shower. I realize this is saying there's much less hot water in the tank that's actually as hot as I want it! Would this...
Hello, Your 20 year old water heater is nearing the end of it's useful life. Most water heaters last only 20 years before they start to leak. The reason most likely it has intermittent heat spurts is most likely due to two things, 1. The unit has a lot of rust in the water (you don't normally notice it during a shower) If you were to bleed off the rust by attaching a hose or bucket to the bottom of the heater's water outlet, and /or the over pressure tube located off of the top of the unit that has a copper pipe on it pointing toward the ground, that you would see a lot of rust come out of it. You could do this and get a bit more life out of it and better heat to boot, unless it decides to leak.
2. The water heater has a bad electric heating element (if it's electric that is). Replacing it may solve the problem but most likely the heater still isn't going to last too much longer anyways, so that would be a judgement call on your side.
You would in all likely-hood be better off replacing the entire water heater now while it is in a controlled environment before it leaks at some unfortunate time causing water damage and other damage at the same time when you are not around to control it.
Good Luck! Rich L.
Jan 02, 2011 | Water Heaters
No hot water just quit suddenly
First, of course, check your breaker in the breaker box. You will need to check to see if the heater is getting power before checking the element(s). Elements go out suddenly, so this could be your problem if you have a smaller one-element heater. Have it checked. Good luck.
Nov 30, 2009 | Reliance Water Heaters
Water doesn't heat up hot enough
The problem is more than likely not the dishwasher but you water heater. I have this problem because there is a long run of pipe between my dishwasher/sink and my water heater. I have to run about 2 gallons before I get any hot water you can do the same thing to "prime the pump" as it were. Also you may have your water heater set too low to sanitze dishes. This can usually be corrected by turning the nob to "warmer" or "hotter" on your water heater. CAUTION: If you have small children or handicapped individuals in your home who could burn themselves you may want to think twice about turning up the temp at the water heater as the risk of severe burns increases greatly with very hot water coming out of the tap. Some dishwashers have an axuillary heating element in them that adds extra heat to the water before/during the wash cycle if you have done nothing to your water heater or have not had the previously mentioned problems it is possible that this heating element has failed and needs to be replaced. If so best to call a service company and ask for an estimate.
Oct 26, 2009 | Maytag Dishwashers
The heater no longer keeps the water hot. The warmer still works.
here are three possibltys a burned off wire in the heating curcuit .but more likly its the hi temp cut out or the thrmostat itself. a continuity tester can determine with it is . both part are easily replacable
Dec 19, 2008 | Bunn Pour-O-Matic VPR
Bunn Pour-O-Matic  VPR Logo
467 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
