Question about Dishwashers
LG Dishwasher model LDF7811 doesn't clean
Dishwasher doesn't clean the dishes. My gut feeling is there is no water pressure from the pump. The inside of the unit is developing mold. I now occasionally run the unit empty with bleach just to keep it clean. I have checked all the water pathways for dirt and there all clean. LG 24 in LDS 5811 WW White Dishwasher doesn't wash or dry.
We were disappointed the day we installed it.
It has gradually gotten worse. Now there's not even enough pressure to spin the washers. It stinks every time we open it. Right now we're washing the dishes by hand.
Have taken apart everything that might hint of being plugged up and pressure washed them. Makes no difference.
3 Suggested Answers
  • 60 Answers
SOURCE: LG Dishwasher model LDF7811 doesn't clean
If the main pump failed it would generate an error code so it's more likely something has gotten down into the sump area. Try taking the screws out around the mess screen and sump area and open that area to look for something inside. Note: To remove the impeller it is a backwards thread.
Posted on Jan 03, 2008
LG DOES ****. We had this dishwasher and from the very beginning it didn't seem to dry and within a few months it was not cleaning as well as we had hoped. Within 9 months it had gotten so bad that we were really unhappy and then we got an error code. LG arranged for a local repair company to take a look at it. They ended up replacing EVERY part of the dishwasher except the tub itself. They replace the pump, the heater, the whole door assembly, the wiring harness (the wires had started melting into the sound proofing material), the electronics. Literally everything. From that point on we really noticed that we were getting food chunks on everything. Not only that, all the dishes were greasy and it wasn't even coming close to drying. There was mildew and mold growing inside the tub! Finally I got fed up and threw a fit with LG. They sent another repair guy out and he told us it was going to take 3 weeks to get a brand new pump and heater because the replaced heater had failed. After I complained to LG the repair guy got the parts in a week. He quickly replaced it and tested it and it flooded our kitchen (hardwood flooring) and leaked through the floor to the ceiling downstairs. The new heater was faulty. Not only that, the repair guy told us that the first repair, 9 months earlier, had not been completed and our turbulence detector had never been hooked up. Our solution? We fought with LG and Home Depot, where we got it, and LG offered to replace it with a new dishwasher. I said forget it, we didn't ever want an LG dishwasher again. Home Depot stepped up and took back our 2 year old dishwasher and refunded all our money. We bought a KitchenAid and we LOVE IT!
Posted on Oct 12, 2008
Whirlpool Gold Dishwasher- bowls in center of top rack are full of water, bowls in corners have almost no or no water in them and dishes on top rack are dirty. Dishes on bottom rack are clean.
First try running a cycle of "Dishwasher Magic". You can find this at Walmart for around 5 bucks. This will clean and condition the inside of the dishwasher and the inside of the pump and motor.
If this doesnt help...and the plastic and/or metal components in the dishwasher seem to look and feel intact..this would lead me to believe there is an issue with the pump and motor. These are sold as 1 unit or as seperate units depending on the model. Changing it is simple if you know how to dissconnect and reconnect a dishwasher. Take into consideration the age of the unit, the cost of the part, and the cost of a total replacement.
Oct 29, 2013 | Dishwashers
Having trouble with dishwasher- I feel like dishes are not getting clean- will replacing circuit board on dishwasher help dishing become cleaner?
You may need to clean out the filters that keep food from being pumped up to spray out of the sprayers. This will depend on your make and model as to how to do this. Clogged filters will reduce the amount of water being sprayed. Try opening the door mid cycle to see if there is a vigorous spraying action. If the water being sprayed is underwhelming, it may be clogged filters.
Feb 13, 2013 | Maytag Dishwashers
The lg dishwasher doesn't use all of the detergent and the dishes are not 100% clean
first check the water supply if good water pressure.then check the pump under the bottom dish tray remove parts check for debree.
Jan 25, 2013 | Dishwashers
I have owned my LG stainless dishwasher for 3 years with no major issue. But now when the entire cycle is complete there is a white film that remains on the dishes. I have switched detergents but it...
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
Aug 17, 2010 | LG LDS4821BB 24 in Builtin Dishwasher
Dishes come out pitted and feel dirty. I have
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Nov 08, 2009 | Frigidaire 24 in. GLD2162RDC Stainless...
Dishes stay greasy
On this LG LDF7811 dishwasher, are you getting any error coded in the display?
If no, buy a small box of name brand dishwasher detergent powder (like cascade or electrosol) and use it for two loads, but do not over fill the soap dispenser cup.
If problems continue, it is time to clean everything under and in the filter assembly that is below the lower spray arm (silver phillips screws.) Search for any debris.
Please report back what you find, and we can take the next step, OK?
Sep 13, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Upper rack sprayers not working on LG ldf7811 dish washer
Check the pump out. Even though the Hose is and tubes are clear it does not necessarily mean that the pump is not pumping water to the top sprayer. One way you can do this is take off the upper spray tube and lay it in a glass or bowl and turn on your machine for a minute or so to get the water flowing if it flows then I would take off the spray assembly itself and make sure that there is no blockage on the bearing race
Apr 08, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
We have an Admiral Dishwasher that won't clean all the dishes properly. It leaves white film residue on some of the dishes and silverware. Have tried different products to clear this up with nothing...
Apr 04, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
Dirty dishes on lower rack
Please confirm that you own an LG LDF7811 dishwasher and it is not cleaning properly.
-Are you getting any error codes displayed? -Did you remove the mesh filter and clean any debris beneath it plus rinse out the filter itself?
-Are you using a name brand diswashing powder? Avoid ultra-cheap detergent, especially in water-conserving units like the LG 7811. Never use DW gel or tablets in any dishwasher.
-Do not over rinse the dishes before placing them in the DW. The food granules actually are used to clean all the dishes before being rinsed away.
Please try these suggestions and reply to this message with what worked best and if the problem continues. Good Luck!
Aug 25, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Jan 01, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
