The diagrams on line describe a different box that shows four relays sitting forward of the main fuses and none of them are labeled fuel pump relay. Is the relay someplace special? under the car, next to the fuel pump. someplace only swedes could appreciate?
SOURCE: 1985 Volvo 240 no fuel no spark
well first the fuel pump relay is bad, that is easily replaced. next you have no spark. the first thing you do is take the cap off the distributerand crank the engine. if it spins that tell syou thyat at least the tang or gear on the shaft of the distributor is ok and not broken. next thing is remove the #1 plug and use a 1/4 drive extension 6" long and turn the crank by hand until the #1 cylinder is top dead center(put the extension in the hole of head where the plug was and you should feel the top of the piston also make sure you can feel the top of the piston with half the extension this way you don't drop it in the cylinder with the piston at TDC(top dead center) the rotor of the distributor should be pointed at the #1 firing position. IF it does not that means your timing is off and you need to retime it by taking off timing cover and either replacing the belt/chain or gears. now if you do not have a distributor and you have a coil pack there could be only 2 things that won't give spark. either a bad coil or your altenater is bad(the battery is responsible for starting not running the vehicle like alot of people assume. the altenator energizes the coil which inturngives spark. hope this helps you please rate this thanks
SOURCE: 99 volvo s80 fuel pump getting no current. Fuse OK but can not find relay between fuse and pump
ther are good few types of fuse box for this car.but if it has 6 relays along the bottom its relay number 28hope this helps
SOURCE: 1990 Volvo 240 DL brake lights not working, fuse good, bulbs good
It's silver aluminum---not orange---that's fuel pump!
SOURCE: Volvo V70 wont start - suspect main relay - where is it located
My volvo v70 has three places for fuses and relays, one under the bonnet, one on the end of the dash board on the drivers side, and one the boot on the left hand side you may find what your looking for in one of these places
SOURCE: Volvo headlight problem
headlight relay is the problem. it is located in dash above radio in a fuse cluster. local autozone can tell you exactly
Doh! There is a second fuse box behind the main fuse box. It's all there.
