Question about Oster 12-Bottle Wine Cellar - Black
The fan does not go on
My Oster wine center is less tha 1 yr. old. The fan does not go on and therefore it does not cool.
  • 3 more comments
  • fitema06 Dec 20, 2008
    fan not working
  • Anonymous Dec 29, 2008
    Where is the fuse??????????????????????????
  • shawnboy04 Feb 27, 2009
    so is there any way that some one could email me a picture of these fuses to check?all i see are diodes.. thaks and my email is shawnboy04@yahoo.com thanks agin.
  • coboremy Mar 01, 2009
    I had the same problem and replacing the fan control fuse on the board solved it. Thanks for your help!
  • Custom Exchange
    Custom Exchange May 11, 2010
    With a voltage meter read to see if you are getting a reading at the wiring at the fan
    Problem Solver:
  • 7 Answers
Ther are two fuses in back panel of unit. One fuse can be seen other is hidden top left of panel and is coated in black shrink rap. I had to replace that fuse to correct the problem. Problem is I had to cut away shrink rap and resolder another fuse, you may have to have someone who can do this look at your uint. Hope this helps.
Posted on Feb 23, 2009
Stopped cooling no humming or nothing digtal reading are working but nothing else
you need to replace the fan at the back of the unit. no noise means the fan is not working. The fan removes the heat from inside the unit to cool it. no fan, no cool. Your local appliance repair can fix it. the fan does not cost much and there isn't much labor involved. If you want to tackle it yourself then take your model number to the appliance store and order a fan, remove the back and replace the fan. Some fans are plug and play, some are not. if yours is not plug and play then you will have to splice wires. either way, the fan is your problem.
Nov 23, 2010 | Oster 12-Bottle Wine Cellar - Black
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Taking a long time to cool down and when does the fan kick on
the evaporater fan should be opperating when the compressor is runnig ,as well as the condenser fan if you have one
May 19, 2009 | Oster 12-Bottle Wine Cellar - Black
Will not cool
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Oster 12-Bottle Wine Cellar - Black
Oster Wine Opener---4207
Hello Georgian!
We have a friend who lives at Berkly Lake, and we went to a wine boutique if you will over near her house. I think they would know who services that unit. I can not think of the name of the store though, but it was pretty close by (3-4 miles) in a small business strip center. I know your close by, being in Peachtree.
Alternative, is to find a Oster appliance repair center. There has to be one in the Atlanta area for sure. Or really, any appliance place that services refrigerators. Heck, I (with my wife), it's her best friend) would come do it for the price of a plane ticket. Our friend could vouch for my knowledge.
Jan 28, 2009 | Oster 12-Bottle Wine Cellar - Black
Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster wine cooler (peltier diode)
I called the contact in one post below, and he was VERY helpful. Took all my info, submitted to the division handling this and they overnighted me a check for the entire amount plus tax for the wine cooler to me! Call Jason!
Jason's contact info is:
Jarden Consumer Solutions
2381 Executive Center Drive
Boca Raton, FL 33431
(561) 912-4100
Jun 25, 2008 | Refrigerators
Oster 12-Bottle Wine Cellar - Black Logo
164 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
