Question about IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3500.
My wheelwriter 3500 types incorrect characters. Is this my printwheel or another problem?
  • peg1943 Dec 22, 2008
    No, the display does not show aP/W number other than 001
  • IBM Master
  • 3,594 Answers
Does the display show aP/W nomber other than 001?
If it does hold the code key,press and release the "L" key type 001 release the "L" key this sets the keyboard to U.S., if this works the cure is to replace the keyboard.
DickyO
Posted on Dec 19, 2008
How do you change the font size on the ibm wheelwriter 3 typewriters?
The WW3 will type whatever printwheel is in the machine. If you want something different you will have to buy another printwheel. It says on the printwheel whether it is a 10 pitch or a 12 pitch.
Jun 29, 2010 | IBM Wheelwriter 30 Typewriter
Here is my issue with my IBM Lexmark 3500 wheelwriter: It is screwing up, when it's printing, first, everything is okay then all of a sudden, funny characters are coming out. I think that the language...
First try another printwheel, check for bent spokes on the P/W. If all is OK try a little WD40 on the front and rear bearings of the selection motor. It is located below the ribbon deck near the center of the printer.
DickyO
Jun 09, 2010 | Lexmark Wheelwriter 3500 Typewriter
How do i change the font size on a Wheelwriter
The font size is set by the printwheel, the printing on the P/W case will tell you the pitch 10, 12, 15 or PS. Change the wheel change the pitch.
DickyO
Dec 07, 2009 | Lexmark Wheelwriter 3000 Typewriter
Typing characters that are not intended
Try these troubleshooting suggestions for your problem:
Wrong Characters Print or Characters Space Incorrectly:
1. Turn the typewriter off, wait 30 seconds, then turn the typewriter
on again and try typing again.
2. Make sure the LANG indicator is off.
3. Try a new printwheel.
4. Look for objects In the path of the carrier.
5. Make sure the printwheel is changed when there is a language
change.
6. If you are playing back, make sure you use the same pitch
printwheel you used when you typed the text.
You can download the Operator's Guide for your typewriter from here (it takes a little while for the download to begin):
Wheelwriter Typewriter 30 Series II (6787) Operator's Guide
Aug 20, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter II characters above the numbers print incorrect.
You may have an unusual printwheel that has special char. on the P/W, or you may be in the language mode hold code and press "L" key.
DickyO
Mar 10, 2009 | Lexmark Wheelwriter 3 Typewriter
Writer beeps w/keystroke and does not type.
You are probably in a format mode that was set up for 12 piych printwheel. Install a 12 pitch pwintwheel or exit the format mode.
DickyO
Dec 31, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3 typing incorrect characters
If you have another printwheel try that, if you still have the trouble try blowing out the area where it is in stalled. If that fails turn the machine off then back on, after it completes the POR mark the printwheel with some white out, repeat the POR see if the mark is in the same place, if it isin't you probably have a selection plate problem.
DickyO
Nov 11, 2008 | Lexmark Wheelwriter 3 Typewriter
Character spacing
Joany, look for a function,usually on the left side of the keyboard on the IBM,that has the markings 10,12 and 15. And if my memory is correct,there will be a series of lamps which light up at the selected pitch. I would look for a key marked "pitch" and press that. Good luck.
Nov 21, 2007 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
196 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
