Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Hitachi 50 inch projection tv
My tv started showing doubles in the screen i open the panel box and push the test pattern button which usually show a white cross in the middle but it only showed the red and blue lines out of place. Also the blue on the horizontal is not working. Is the convegence ic's or the video board going bad please help before i purchase another set.
  • Hitachi Master
  • 5,138 Answers
Convergence ICs replace them bot 2 big black ics STK392-560s not sure what your STK numbers are but use same number to order parts call Electronix Parts 1-800-223-3205 PS if they are using 110s use 180s if 020s use 040s better ics.
Posted on Dec 19, 2008
My toshiba tv 60 inch shows a blank screen.when I start it toshiba sign shows then blank screen why and how to solve
if the power button flashes in a pattern note down that pattern and repost the query with that included...presumable the power button light does not go out.
Jul 26, 2015 | Toshiba Televison & Video
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Mar 27, 2010 | Hitachi P50H401 50 in. Plasma HDTV
My Hitachi TV is showing a double vision on the lefthand side of the screen.
Your projection lenses are probably covered in dust. My TV did the same thing with the blue color on the right side. Usually you can get to the projectors from the bottom front or back. Goo luck.
Mar 10, 2010 | Hitachi Televison & Video
Hitachi projection tv showing double
This sounds like a convergence problem. Not sure but, the IC's are STK 392-110 or the last three digits could be 150, 570, ect... These IC's look black and about 3 in x 2in and have 12 to 15 pins. They will be mounted to a heat sink (a piece metal) They will be screwed on or a metal tab clip holding it on. Look on the IC for the numbers, then you can order the right one for your set . Hope this is helpful.
Nov 15, 2009 | Hitachi Televison & Video
Seeing doubles
there is an adjustment called convergence.the convergence setup generates a crosshatch.you need to adjust the red deflection.this is a common thing when the t.v gets moved.the crosshatch or convergence button is mostly on the front control panel.consult the manual for where it is.
May 22, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Where Can I Buy A Replacement Screen For Hitachi 51f59a Rear Proj
Hi, I have a brand new in the box screen for a 50 inch rear projection tv. I was going to put it on ebay but if this is what you need and what I have--well we can go from there. Email me with any questions you may have. Thanks, wrapper494@msn.com
Mar 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
My Toshiba 50 inch projection screen TV isnt displaying
If you are capable of some basic troubleshooting you can determine what's wrong but you won't likely be able to fix it yourself. If you remove the TV's back panel, you can locate three plug connectors for the convergence correction yokes. You pull the red, blue, and green connectors and then plug the TV back in and hit the power button. If the TV comes on, its a failure of the convergence output ICs and will cost $350-450 if you call in a service company.
michtech
Feb 14, 2009 | Toshiba TP50G60 50" Rear Projection...
50 inch hitachi green screen all the screen has a strong tint of green tried picture adjustment dont even get it close
I have the the same problem with my 60 inch Rear HD projection Hitachi. The bad part is we just bought a bulb 2 months prior to the green showing up.
Jul 02, 2008 | Televison & Video
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
