By changing the domain configured in postfix to be the same as the server is configured as, mail will start to come in.
According to the logs, they still seem to get looped through your ISP smtp server, but at least they get delivered eventually.
Sir,
When launching an application on your Palm OS powered handheld or smartphone, the error '(Sys
0505) (0,841)' appears, tapping OK causes the message to go away and the application list is
shown.
This is a compatibility problem related to d-pad navigation support. Downloading the latest version
will resolve the issue. Please visit:
http://www.iambic.com/upgrade/
to obtain the latest available version.
thanks
goodluck
Back light File probleme delet it problem solved chck this out
You need to push the small reset on unit and the problem should be fixed!
Authentication = username & password
communication is ok since the email server responded with the error.
verify details with your provider.
Try first to remove the email account and set it up again and make sure you put in the correct settings for it...
Please do a hard reset.This will fix the issue but you will loose all your info and data.
What excaclty are you trying to do when you get this errors and also can you provide more information from your PDA like what make and model and what serv provider you use. Thank you!
Error (sys0505) and (0,8410) seems to come up at random times. The Err.(Auth) only on the e-mail attempts to connect to the server.
The e-mail provider is Shaw.ca.c
My unit is the Palm T|X.
