Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
Need a part number
Little rubber roller that pulls the tape across the head has fallen out and I want to order but do not have a part number
Camera DCR-HC20
  • hagentim Dec 19, 2008
    You rock!! Happy Holidays!!!
    Is it possible to get just the roller part?
  • 10,594 Answers
You need to order required part under following part number...
X-3952-934-1 ARM ASSY, PINCH
as shown in below image...
Good luck.
Posted on Dec 19, 2008
  • Shahid Electronics
    Shahid Electronics Dec 19, 2008
    What about rating the solution, 4 blue diamonds?
    Pinch arm assembly is considered one part and it consist of pinch roller, roller lock and pinch arm.
    Pinch roller individually not available.
My GR_SMX730U VHS camcorder is eating the tape.It uses a PRO TC-30 casset.
that means the head is sticky or the takeup rollers are icky
take it apart . clean all the parts the tape touches with something thats strong but little water .
as for the head very carefull clean it when you get to the actual holes where heads are only use a proper qtip wetted . look it up or youll break them.
on the rubber rollers scrub them . then load the tape an watch it run.
its easy to fix this but you need a nice clean place an some small phillips , take pics of parts/screws if needed
Jan 12, 2015 | JVC GR Video Cameras
When i select print I hear it running but label does not move. I changed batteries and I cleaned roller. Is the piece across from the roller suppose to move to guide the label thru?
The rubber roll is supposed to do it. Since it is clean, pull out some tape and try again. Otherwise, please contact our help desk. The numbers are at dymo.com.
Apr 09, 2011 | Dymo LetraTag QX50 Thermal Label Printer
Cassette gets entangled, and does not play well
Cassette tape machines will occasional require maintenance after a certain period of usage. First open the cassette door and remove the tape and any broken tape remaining inside. Some models allow you to remove the cassette door allowing you to have better access to clean the unit. Next you will need to clean the capstan with alcohol and a Q-tip. The capstan is the metal post which the rubber wheel (pinch roller) pushes against to drive the tape across the tape head. Basically clean all the shiny metal parts including the tape head. Some of the tape residue may be difficult to clean, I use Tricloroetilene which has been regulated by the government, but you may try a product called Goof Off to clean the difficult parts, but it could eat the plastic and rubber parts so be careful. Next use a rubber cleaner on the pinch roller so you do not dry the rubber out, or it will become useless. The other problem is the cassette may be driven by a motor and belts. The belts may need to be replaced and the pulleys cleaned. For this you will need to disassemble the unit to access the belts but the cleaning of the pinch roller and capstan may fix your problem, if not you need to open it up to replace the main belt.
Jun 23, 2010 | Philips 3-Disc Changer FW320C Cassette/CD...
Audio cassette tape broken. How do I repair?
Radio Shack used to sell a splicing block and tape for fixing broken tapes. They may still, and you can order online from other sources.
You need to pull the tape out from the cassette a little way. Overlap the tape sections a little and get them aligned, which is what the splicing block is for. Cut across both pieces and take away the scraps. This makes sure the pieces match up. Lastly you place special splicing tape over the join and trim the edges. You need the special tape, since it's designed so the adhesive won't ooze out and get on the tape recorder heads.
If the tape has come loose fro the hub inside the cassette, you need to open the housing and use the splicing tape to fasten the recording tape (actually the plastic leader tape) back in place. Depending on how the cassette was made, there may be screws holding it together, or it may have been glued. Some commercially-made music tapes and bargain-grade cassettes weren't made to be opened. If you do open the tape, don't lose the little metal piece with the felt square that goes across the opening behind the tape. This is the pressure pad that keeps the tape pressed against the head in the recorder. Without it, the tape won't work properly.
Apr 12, 2010 | Electronics - Others
Sondy Camcorder DCR-TRV240 rubber roller loose in tape door
See below picture and find location of small rubber roller.
Sep 25, 2008 | Sony Handycam DCR-TRV240 Digital Camcorder
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
Jul 29, 2008 | Panasonic PV-V4021 S-VHS VCR
Canon uc-1 video 8mm camcorder
Yes it can be fixed, but Canon is not the easiest to work on. Is the connector loose at all? The audio head may be dirty. This is not on the spinning heads. If you look inside and locate the pinch roller (rubber roller), there should be a silver head that looks like a cassette tape head. Try cleaning that using a cotton swab and alcohol. See if that resolves the problem.
Keep us posted.
Dan
Jul 23, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
Vidio tapes are chewing up
This is the number one failure mode for a tape machine.
One drive is used to pull the tape out and run it across the heads very accurately, and another drive is used to pull the tape back into the cassette. This one uses a clutch to allow it to slip so that the takeup reel in the cassette can vary in speed depending on how much tape is on it. After a few years, it slips too much and can't pull the tape in fast enough. (older units use rubber idler wheels to do the same thing)
Either tighten up the clutch, or replace the rubber wheel.
Hope Ya Fix It!
Feb 08, 2008 | GE 27GT616 27" TV
Bad picture
try cleaning the tape path, especially the rubber pinch roller, with an alcohol swab....but how is the performance as a web-cam? (when connected to pc)? if same result, then problem is deeper, maybe CCD
May 31, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
216 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
