Question about Chicago Pneumatic CP826T 3/8 Inch Standard Duty Air Ratchet
Parts i am trying to find parts for my cp826t air rachet. can not seem to find any
    President:
  • 2,976 Answers
They keep them low priced so you can just buy another. The warranty is for complete replacement in a certain time period, if it fails. These are not rerally intended for industrial use.
Posted on Aug 09, 2009
Need repair kit for AT200A 1/4 in. blue point air rachet
This Product is no longer available and or the Repair Parts.
Nov 14, 2013 | Chicago Pneumatic 1/4" Air Ratchet
Cant remove the flat plate which is under the burner
I have the same problem,You will need a 15/16 socket and a rachet.Remove grill,then burner cap to expose range mounting nut use socket 15/16 to remove this work all the time for proper cleaning, NOW HERE IS THE PROBLEM, The nut is brass and it is screwed to the orifice holder,which seems to be made of aluminum.when i tried to back off the nut it freez up and continue to get tighter,as if it is cutting new threads in reverse,so im wondering if this metal combination of aluminum and brass is good,and if the severe heat in its path is not fusing the metals together.still trying to find answer.
KENTEMPO
kenklok@hotmail.com
Oct 31, 2013 | Jenn-Air 36 in. CCG2523 Gas Cooktop
What's best tool to remove riding lawn mower blades?
1/2" impact rachet air the only way to go
Oct 25, 2012 | Craftsman Garden
Craftsman 3/8 ratchet model 875-188020 no power
Check the O-rings in the rachet, itf they are leaking then the rachet will not work.
Jan 11, 2012 | Craftsman Air Tools & Compressors
Ive been trying to remove my spark plug from my weed eater excalibur 22. and im using the right socket wrench for it but the spark plug wont come out
They can ce very tight, they are put in with air tools from the factory, try a 1/2 rachet spanner with a suitable socket.
Jun 14, 2011 | Garden
I have a milwalkie 1/2 inch drive air rachet ...all of a sudden now it wont work when you hit the trigger air just comes out where the top of the rachet joins to the bottom half...is there a way to fix it?
it sounds like the viens in the air motor may be stuck. try pouring some "Air Tool Oil" or any thin oil will do, even veg oil. when pouring it in make sure to pull the trigger so that the oil goes into the ratchet. let it soak for a while and try it. I hope this works for you.
Apr 16, 2011 | Air Tools & Compressors
I am trying to loosen the belt on the alternator and while I am using a 3/8" rachet and turning it clockwise, there is very little tension being made on the belt. Plus, the air intake cover is in my...
i suggest you get yourself a belt tensionner tool, it's not expensive and it will take you way less time to do this. available at any part store
Jan 04, 2011 | GMC Yukon XL Cars & Trucks
Trying to install new serpentine drive belt. Doesn't look like alternator is adjustable. There is a belt tensioner but I can't get quite enough play out of it. Can't really get a tool on it to hold it...
Some of the parts are hard to see. You should have a square hole in the belt tensioner fixture. This would fit either a 3/8 drive rachet or a 1/2 drive rachet. You will put the rachet or breaker bar in the square hole and push against the spring tension.
A trick to installing the belt is not to use the belt tensioner as the last pulley to slide the belt over. Put the belt over the tensioner and use your body weight to push against it. Then slide the belt over the last uncovered pulley and let off your weight on the tensioner.
Sep 06, 2010 | Mercury Mystique Cars & Trucks
Won't agitate. burns up the belt. It seems to be "locked-up". I can get it to spin out the water with a racheting sound.
The Transmission is bad depending on age may still be under warntee Not for labor but parts most have 10 year parts coverage find a pro or buy a new /used one most repair places will give you an estimate of repairs and call if they have problems fixing it
Nov 15, 2009 | Maytag Legacy MAV208DAWW Top Load Washer
Open Questions:
See all Chicago Pneumatic CP826T 3/8 Inch Standard Duty Questions
Chicago Pneumatic CP826T 3/8 Inch Standard Duty Air Ratchet Logo
179 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Marvin
Marvin
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
