Question about Sony Cyber-Shot DSC-P200 Digital Camera
Camera Flash is not working
I am having the camera for the last 1.5 years. For the last few months, the flash is not working even if we turn it on and also the image will be dark if the flash is on. Very rarely it works !!! The AF Illuminator is set as 'Auto'. Everything was working fine initially when I bought the camera. Please let me know what could be the solution for this ... Thanks in advance
    Sergeant:
    Champion:
  • 326 Answers
This kind of error requires a professional assistance. Please contact your nearest Authorized Sony Service for price estimate. The best possibble option for you is if this error is because of poor soldering/contact. Otherwise replacement of complete board SY-123 is too expensive. If you need more info please advice.
Posted on Apr 01, 2007
Lumix DMC-LC40. Flash not turning off even after the flash compartment physically closed. Camera uses flash all the time.
The micro-switch which senses when the flash is retracted has most likely failed. When the flash is closed the switch is activated and tells the camera not to use the flash.
Repair is not a DIY job, the camera must go to an authorised Panasonic service centre. But given that your camera is about eight years old now the repair is likely to cost more than the camera is worth. The part is fairly cheap (if still available), but it's the standard minimum labour charge which is the killer.
Also you'll be wise to consider that as the camera has passed it's six year maximum design life you may get it back only to find that something terminal like sensor failure is lurking just around the corner. It's a fact that very few digital cameras last as long as yours has, so it's arguable that you've had your money's worth from it.
The final option is to treat the camera as a write off and attempt a DIY fix which might actually get it to be useful again. You'll gain valuable experience either way and may actually effect a perfectly good repair.
To do so you'll need to work out how to open the top of the camera to access the micro-switch (make sure that you earth yourself whilst you work using an anti-static wrist strap available from all electronic and computer spares stores). One there you won't be able to get hold of the complete assembly that Panasonic used, but you may be able to either remove just the switch alone and replace it with an equivalent from an electronics store (expect to do some very fine soldering). If you're very deft and with sharp eyesight (or magnifying glasses), you may even be able to open up the switch and replace or fix it with home fabricated parts. But even just bypassing the switch so that the camera thinks that the flash is permanently closed might be an acceptable compromise. Sorry I can't provide any more than general instructions for this, but it's been years since I worked on a DMC-LC40 (if ever!) and have no service manuals for it. If you choose the self repair option then before starting turn the camera on, let the flash charge and fire it outdoors in the dark. IMMEDIATELY remove the battery before the flash can start to recharge and then leave the camera with the battery out for a week. What this does is to ensure that the capacitor which powers the flash is as fully discharged as possible before you risk going near it: flash capacitors hold extremely high voltages and can even be fatal although on your camera it only has to power a tiny flash tube so you're saving yourself a nasty shock and the possibility of frying your camera circuitry.
I hope that I've given you a few useful ideas and that you're able to soon get snapping again. Please don't forget to rate my answer.
Feb 27, 2010 | Cameras
When I put the sd card in and then turn power on it ask to format. no matter if I input yes or no the camera then shuts off
i have this w5 camera for the last 3 years few months back an error appear named E;91: like that and sometimes a beep sond for few seconds also on flash mode i cant take pictures i solved that problem by initialise the settings.now that problem started i initialise and formatted also remove the memory stick and again initialise and formatted but the error continues.i can only take pictures without flash what can i do please give me ur valuable suggestions
Oct 12, 2009 | DXG Technology DXG-572V Digital Camera
Flash stops working
The flash bulb may be broken. Try contacting Pentax to get it fixed.
Jul 15, 2009 | Pentax Optio T10 Digital Camera
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Problem with the Flash Light of Nikon COOLPIX L12 Digital Camera
I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Cheers.
Sep 27, 2008 | Nikon COOLPIX L12 Digital Camera
XTi 400D flash
It appears that the small hook that holds the flash down is not latching properly and perhaps needs replacement. If your camera is still under warranty, call Canon Customer care. Even if the warranty has just expired (like 1 or 2 months), they generally honor it and get the service done free of cost.
Mar 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
White pictures, low battery life, few pictures
I glued a small peice of plastic under the flash and above the camera lens to shade it from the flash when it goes off. I then only had 2 pictures out of 40 that showed a white picture. The plastic peice only sticks out about 1 inch and didn't affect the flash on the subject. I also drilled holes in the bottom and hooked up a 6 volt tractor battery to it this gave me over 1 month of battery life with another identical camera
Jan 21, 2008 | Moultrie MFH-DGS-200 Digital Camera
Charging flash
same problem, exact same camera... I had fixed it already with a guy who fixes all kinds of cameras and he had to change a piece that wasn´t working, but after a few months the problem started again...
Dec 26, 2007 | HP Photosmart R927 Digital Camera
Camera battery is dead and was just bought a week ago
If the contacts have been cleaned in the battery chamber, check the lower contact post - it's spring loaded and often gets stuck and doesn't make good contact with the battery. A little WD40 usually will free it up. Your batteries are probably still good.
Oct 16, 2007 | Canon EOS-AE-1 35mm SLR Camera
Sony Cyber-Shot DSC-P200 Digital Camera Logo
55 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
