Question about Toshiba 52HMX94 52" Rear Projection HDTV
I have a 3 years old Toshiba DLP 52hmx94. We had a PS3 hooked up to one of the HDMI ports. Worked fine for a year. Yesterday it stop working. Can't get a signal, screen has a light green tint. But screen looks like it does when there is nothing hooked up to it. We tried a different HDMI input same thing. Took the PS3 with the same HDMI cable to another TV and it worked fine. Is there some kind of reset I can do or is this typical for this type of set. Thanks Dean
    Genius:
  • 1,112 Answers
Have the input signal board replaced. Might try also replacing the digital board assembly.
Posted on Oct 24, 2009
No video signal using HDMI cable.
This sounds similar to my Vizio's second HDMI port; they sometimes become finicky after a while. You may have to just adjust and wiggle the end of the cable inserted into the TV; if it works, then make sure you don't even slightly touch it or else it'll lose signal again. If you have any other ports, try them instead; otherwise the problem may eventually get to an unusable point. You will have to have the port repaired or the TV replaced.
Jan 30, 2018 | Toshiba 47ZV650U TV
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
My PS3 connects to my 3yr old Mitsubishi HD tv fine via HDMI or the analog connection. However, using the same cable(s) it won't do anything but flash a squiggly green line a couple of times on a 6 year...
yup one or the other is capped at or below 1080 P - I so when you go to power it up at a new tv push and hold power till it makes the second beep 5 secs later and your good to go ok :)
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Open Questions:
Toshiba 52HMX94 52" Rear Projection HDTV Logo
225 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
