Subwoofer internal fuse continues to blow upon replacement
Canton AS 105 SC subwoofer
age 18 mths
fuse T1AL
root cause unknown assume teenager use in playing ''loud'' music
fcollingwood
  • 58 Answers
SOURCE: subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
Posted on Sep 14, 2007
tech240
  • 169 Answers
SOURCE: subwoofer installation
no jack =no sub audio signal so you would have to get some kind of summing filter. this would sum (mix) the two signals together and extract the sub audio from both channels in order to drive the powered sub woofer you have. could be expensive dont know.
Posted on Apr 25, 2008
  • 3 Answers
SOURCE: AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Posted on Nov 13, 2008
Xtremeroofin
  • 67 Answers
SOURCE: What is the amperage for
1-amp
Posted on Dec 23, 2008
  • 124 Answers
SOURCE: My Velodyne CT 80 powered subwoofer does not power on?
Fuse in amp may be blown or the amp is dead
Contact Velodyne, the replacment amp is not very expensive
Posted on Jan 04, 2009
Rw12fuse blown klipsch subwoofer. The new fuse blows instantly. What else can I try?
If it's continually blowing fuses you have an internal circuit problem, best to take it in for repair at that point.
Sep 22, 2012 | Klipsch RW12 Subwoofer Speaker
In love
Please provide more details...valenyine is around the corner
Feb 09, 2011 | Canton AS 60 SC Subwoofer
I have the SB-HW950 subwoofer and teh SC-PT950 speakers and I just purchased a Denon Receiver to replace my DVD/ receiver player. So now I have SC-PT950 speakers playing through the Denon but for some...
Yes, the old Panasonic SC-PT950 did drive the subwoofer by its own amp, such as it was.
http://www.retrevo.com/support/Panasonic-SC-PT950-Home-Theater-Systems-manual/id/2869dj183/t/2/
It's never a good idea to adapt prescribed connectors to bare speaker wire or vice versa.
Speaker Level and Line Level signals are worlds apart and equipment damage may result. Your Denon (model unknown) probably requires a POWERED SUBWOOFER, to which it would provide Line Level LFE from its Pre Out.
Read the manual where it doesn't say to convert a speaker wire to RCA.
Feb 06, 2011 | Panasonic Audio Players & Recorders
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
Subwoofer blows internal 1.25A fuse when plugged in.
Any fuse blowing is caused by an overload in either the power section or the amp part. Look arond for burnt or damaged parts first. It could be caused by a shorted transistor, but your best bet is to follow the circuit from the fuse on the PC board.
Feb 18, 2010 | JBL PB10 Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Polk Audio PSW350 Subwoofer keep blowing the fuse
The brown resin is glue that changed color due to heat and age. Rarely have I seen it cause problems. So unless you are having problems, No.
Feb 27, 2009 | Polk Audio PSW350 Subwoofer
Blown speaker. Canton as22 blown woofer. Where can I buy a replacement woofer?
 try http://www.parts-express.com they are a really good sourch for speaker replacement . i reccommend using daytons.-z
Feb 24, 2009 | Canton AS22 Subwoofer
387 people viewed this question
 Grubhead
Grubhead
