Question about Soyo USB Hard Drives - 20GB Worldâ¿¿s Smallest Slimdrive (660475025719) Drive Case
USB HD not responding
Have a Soyo USB 20GB Hard Drive. When I plug it into the USB port Windows Explorer recognizes it. But when I try to move data to or from it I get a error message saying "Can not find the specified file" I have uninstalled the device in device manager and rebooted, no joy. Apparently the Soyo is corrupted. Any suggestions, Thanks Rich
    Problem Solver:
  • 46 Answers
Why dont you format it, so that you can use it nicely!
Posted on Apr 08, 2007
How do I use a jump drive Hi-Speed 16 GB Stix
You didn't mention the manufacturer on your 16GB stick, but that should not be a problem using it. The price on 16GB USB drives has fallen dramatically in recent weeks, so you will see more of them in use.
If you plug the USB drive into one of your computer's free USB ports, it should be recognized by your computer and assigned a drive letter in Windows. This means if you view the contents of your hard drive using Windows File Explorer, you should see another drive representing the 16GB USB thumb drive in the list of disks.
If you click on that drive you will see its contents (if any). Some drives come with software pre-loaded on them which you may be able to use to encrypt the contents of the thumb drive.
In all other respects, the USB drive will function like any other disk drive, allowing you to move or copy files back and forth between your main hard drive and the USB drive.
Be careful to 'unmount' the USB drive before you remove it from the USB port. Often there will be a flashing LED light on the drive which indicates that data is being written to the USB drive. If you remove the drive while the light is blinking, you may damage the file system on the USB drive and make reading its data impossible.
To eject the drive properly using Windows File Explorer, click on your main hard drive (usually C:) to select it, then RIGHT-CLICK on the drive you want to eject. A menu will come up, and you should click 'Eject' to close out the USB drive. You will get a confirmation message window that it is safe to remove the drive.
Oct 02, 2016 | Electronics - Others
Remove drive from Arcdisk 20
If the power plug on the drive doesn't work, putting it into an external case is pointless.
Dec 30, 2013 | Archos ARCDisk 20GB 4200rpm 480Mbps USB...
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
My buffalo drivestation external harddrive don't power up?
A USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
Jan 02, 2013 | Buffalo Technology Buffalo 1TB Drive USB...
HD-PE250U2 had it for 3 years - very much loved and working last night. Computer will not recognise it this morning - but power and blue lights are on. Computer does not register the 'name' of
Either the hard drive went bad or the electronics of the enclosure went fubar. Suggest you remove HD and directly connect it to your desktop computer to see if the cmos recognizes it along with the OS. If so you can access your data. If not, the drive is ng - if the drive at least spins and is recognized you may be able to retrieve the contents using windows explorer. If unit will not spin you are in deep doo doo.
Do not format - that will erase everything - try to access the data.
Sep 03, 2017 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
Western Digital external drive not responding
Unplug it and plug it in to a different USB port, shut down the computer
and while the computer is off, turn on the drive.
Then restart windows with the drive on, now after windows starts, wait about 5-10 minutes, if the drive does not start to blink, (the light),
then go to there website and get there hard drive Diagnostic disk,
you can download it.
This is the download page, read the instructions on how to run the tester on the drive.
http://support.wdc.com/product/download.asp?groupid=101&sid=3&lang=en
Feb 15, 2010 | Western Digital 320GB MyBook External USB...
My pc doesn't recognize my verbatim 1000gb external hard drive, error "unknown device"
Did the 1000gb external hd come with instructions?
Did you read them?
Did you Install The Software for this Device?
If not. Try plugging it in all the usb ports.
Try shutting down the PC, when it's off plug in the 1000gb external HD,
Restart the Computer, If Windows still dosen't recognize it, then it's most likely defective, and should be returned. Try purchasing a higher quality brand.
Nov 20, 2009 | Verbatim VER95327 USB Hard Drive
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Fantom GF1000EU Hard drive: When I turn the drive on my computer recognizes something is plugged into the USB, but it is unable to locate the drivers. The drive also does not show up in my computer.It does...
there is extra port of power and data attach in hdd and also use cable join this port. some time this port and usb cable loose and damage so we can not look hdd in computer. once atime change another case to check hd. (nepal)
Oct 13, 2009 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
I accidently plugged in the power Data plug only and now my computer does not recognize it when I plug both power and power-Data And it wont let me reinstall What can I do
Change the USB port to another.
If you have things in the other port, then move one of those to the port the FA is plugged into now.
This will force Windows to reinstall it.
Apr 16, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
85 people viewed this question
Top Soyo Computers & Internet Experts
Marvin
Marvin
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
