Rheem Fury 40 Gallon Natural Gas Water Heater Logo
Christopher Graff Posted on Aug 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't locate the year of manufacture of my Rheem Fury Model 29-40S-2
Just bought this house in April and the water heater went out. Was wondering how long it lasted before making a huge mess in the basement. I know it was at least 12 or 13 years, but guess it is more. Just curious.
Gene Haynes
Level 3:
  • Rheem Master 5,391 Answers
  • Posted on Aug 20, 2012
Gene Haynes
Rheem Master
Level 3:
Answers
5391
Questions
0
Helped
2605860
Points
14124
Generally the year of manufacture for Rheem is 3rd and 4th digit of serial number. 06 is 2006, 92 is 1992 etc.
Older gas water heaters are better than new ones, and easier to keep repaired and maintained.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Regardless of age, the key factor is whether tank is rusted, or rusting.
Open drain valve and check if water is rusted.
http://waterheatertimer.org/Replace-anode-rod.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5 Related Answers
Thomas F. Schneider
  • 2715 Answers
  • Posted on Jan 31, 2009
SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Anonymous
  • 92 Answers
  • Posted on Apr 16, 2009
SOURCE: flush Rheemglas Fury 22VR75 yearly-increase life of H2O heater?
yes you will increase life if you flush sediment yearly
Anonymous
  • 332 Answers
  • Posted on Jun 06, 2009
SOURCE: the water heater will cycle 5-6-7 times with no
there is a screen around the bottom of the unit? if so take it off and clean it,, does this unit have a self ignitor, or is it piliot? make sure your flue is clear so the unit is not over heating,, make sure on the power vent that the filter is clear also,, does the fan come on before the gas ignites, if not the circuit board is going bad the fan should start first to omit the gas fumes
HANK MCNEIL
  • 252 Answers
  • Posted on Oct 23, 2009
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
Paul Carew
  • 3808 Answers
  • Posted on Jan 24, 2010
SOURCE: We have an older Rheem Fury (gas) water heater and
Hi I would try changing the thermocouple
1helpful
Rheem Fury Gardian 40 gal LP water heater pilot will not stay lit
1) Clean air intake (flame arrestor):located under combustion parts and look for broken glass from TRD
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
2) Troubleshoot by type of gas control, and link to AS Smith service manuals
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Add a comment with more information
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2answers
Need to know the year of my tank RR410T
the age of all water heaters is listed under the serial #, not model #. you will have to call a plumbing supply house that deals in your brand of waterheater, a.o. smith, ruud, bradfordwhite,etc.
Hot water steam is coming out of the center hole located on the top of the Rheem fury 41v50n
Turn water heater off so it doesn't rupture.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Sounds like tank is rusted out.
http://waterheatertimer.org/Leaking-water-heater.html
Replace water heater. You can limp by for a while with rusted heater by turning it on for short periods when you need hot water. Then take time to find best deal on new heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
1helpful
I just bought a house, and the water heater instructions posted on the water heater is all covered up by the earthquake straps! The earthquake straps are a requirement in California, I can't remove them....
1) Model 41VR50N is Rheem fury gas water heater.
Look on tank label, the second 2 digits of serial number are year of manufacture.
2) Rheem does not show that specific model number, but has generic manuals for Fury series:
Open link to read about Fury series, and access brochures and manuals.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
3) Sample manual for Fury appears on following link:
http://globalimageserver.com/fetchDocument.aspx?id=01091171-3bac-4cb9-a0a8-a11aac3bd668
4) Rheem phone number: 1-800-432-8373
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL NUMBER 81V52D C SERIAL NUMBER RH 1297B30669 50 GAL US TANK ELECTRIC WHAT IS THE UPDATED VERSION?
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
7helpful
Does the Rheem Fury model 22V50F1 qualify for an energy tax credit?
Unfortunately, no... According to the Rheem website, the Rheem Fury model 22V50F1 has an energy factor of 0.58:
In order to qualify for the credit, the energy factor must be 0.82 or greater...
2answers
Dear Hank McNeal; I have successfully used a "boiler plug" to seal a water heater tank leak in 2007. It was a 100 gallon electric commercial hotel unit. To this day it's still in use. It depends where the leak is located....Predrilling the leak is necessary to be sure the plug will ernguage it's threads into good material... Start as small as possible, then use the best suited plug. they come in an assortment of sizes. rheem-glas-fury-model-22-40-gas-water-qbzdprdp3yetvbzozs4dsujq-4-0.jpg
Our water heater is still working after 32 years. Model 22-40-2
not a record, I actually just did a chang out in Annapolis Maryland the had just the 2 wires running into the unit. you know the way houses used to be run back in the 40's just wires no casings, they screwed right to the back of the water heat to 2 screws ans wing nuts, it was a rheem electric
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
