Question about Ricoh Aficio 2015 Copier
One side copy dark
I all ready adj focus and slits under exposer lamp
  • 38 Answers
Clean the mirror of optics section if the problem is same try this,,,clean the polygonal motor in clean cotton cloth with some alcohol
Posted on Jul 07, 2007
  • Ronaldo Panlaqui
    Ronaldo Panlaqui Jul 07, 2007
    DO YOU KNOW WHERE THE EXSACT LOCATION OF ROLYGONAL MOTOR? (BEFORE DO THIS MAKE IT SURE THE COPIER IS SHUT DOWN) IN A LEFT SIDE REMOVE THE 2 NUTS THERE...AND AFTER THAT REMOVE THE COVER SLOWLY...AND INSIDE YOU WILL SEE A SOMETHING BLACK BOX...REMOVE THE CONNECTION WIRE IN BLACK BOX AND REMOVE THE 4 NUTS LOCATED INSIDE THE B-BOX...USE A SMALL PIHLIP SCREW DRIVER AFTER REMOVE THE 4 NUTS REMOVE SLOWLY THE B-BOX.(REMEMBER THE POSITION)REMOVE THE B-BOX GOING TO OUTSIDE AND THEN OPEN THE B-BOX SLOWLY. YOU WILL SEE INSIDE A LOOK LIKE A POLYGONAL SIZE THEN CLEAN THE MIRROR THERE IN CLEAN COTTON CLOTH WITH SOME ALCOHOL...TURN AROUND SLOWLY...DO NOT TOUCH THE FINGER THE POLYGONAL MIRROR MOTOR. AFTER DO THIS BRING IT BACK SLOWLY ALL YOU REMOVE.
  • Ronaldo Panlaqui
    Ronaldo Panlaqui Jul 08, 2007
    CHECK FIRST THE D.V UNIT...B4 YOU CLEAN THE POLYGONAL MIRROR MOTOR
  • 22 Answers
I would check the scanner slit glass under the toner cartridge. Clean the optics, pull the PCU out and clean the LED erase lamps. After this I would say it was the PCU. I NEVER would mess with the exposure baffles or the focus. http://www.tonerovernight.com
Posted on Mar 31, 2007
Zeiss 30slm slit lamp user manual
ZEISS - 30SL-M Community, Manuals and Specifications ' MedWrench
https://www.medwrench.com/equipment/8412/zeiss-30sl-m
ZEISS - 30SL-MZeiss 30SL-M Slit Lamp, The Zeiss 30SL-M Slit Lamp has 12.5 X Eye ... DOCUMENTS / MANUALSView All ... Zeiss 30 SL-M Slit Lamp Video ...
Zeiss 30 SL-M Slit Lamp - YouTube
? 1:49
https://www.youtube.com/watch?v=EqXkunfZCiU
Oct 6, 2014 - Uploaded by DCSPMedicalEquipment
Zeiss 30 SL-M Slit Lamp BUY IT HERE: http://www.dotmed.com/listing/slitlamp/zeiss/30-sl-m/1722125 Find ...
[PDF]MW Instrumenten.pmd - Medical Workshop
www.medicalworkshop.nl/files/documenten/MW%20Instruments%202015.pdf Zeiss 30 SL(M) slit lamp. - Zeiss 20 SL ... ErgAdap (blue) for Zeiss SL-130 slit lamp. ... deliver full power for the equivalent of three hours of continuous operation.
Camera Attachment for Zeiss 30 SL/M Slit Lamp - Healio
https://www.healio.com/.../journals/.../camera-attachment-for-zeiss-30-slm-slit-lamp
Mar 1, 1988 - Journal of Refractive Surgery ' A new SP 30 camera attachment is now available for the Zeiss 30 SL/M slit lamp. Suitable for slit image, survey, ...
May 14, 2018 | Televison & Video
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Picture on tv JVC 27" AV-27530 is getting to dark to enjoy. During dark scenes you can't see much. Have tried adjusting controls and settings to no avail. Any solution greatly appreciated.
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Jun 11, 2010 | JVC AV-27530 27" TV
Waring Waffle Maker no heat
Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation ,Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Sep 22, 2009 | Waring WMK300 Professional Belgian Waffle...
Dark line when trying to make original copies.
The type of printer you have reads the image you want to copy by passing the paper in front of a image reader (it is like a wand with a light-slit on a side).
If someone passed in front of this reader a paper with something like dirt on it (or typing corrector not dry enough) some of that could stick ON the light-slit, so that the section covered with it cannot read any more the image you want to copy at that point!
Try to make a copy and look from above or aside where that light-wand is located, then try to clean it with a clean hanky. It could involve some technikal skills, maybe you have to loose some screws to get to it.
If dirt stick on it after this, try with some alcohol (no solvent please!). After cleaning the reader, copies should come out ok, please let me know.
Rate the solution please! Thx
Jan 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Copy function problem
SCan glass slit is dirty, slit of glass 15cm x 3cm left top,
if not then dirty/worn lamp
Dec 12, 2007 | Brother MFC-7820N Laser Printer
Dark picture
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Nov 23, 2007 | JVC AV-27S33 27" TV
Screen getting dark
Research at www.HitachiServiceUSA.com .......T.
Oct 20, 2007 | Hitachi 57F500 57" Rear Projection...
Ricoh Aficio 2015 Copier Logo
61 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
aaron douglas
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
