Question about Whirlpool GEW9250P Electric Dryer
Whirlpool Duet Dryer GEW9250P (electric)- how do i unlock dryer?
  • Anonymous Feb 01, 2009
    how do i unlock the dryer. It does not have a child lock button.
  • 640 Answers
Its a botton to the far right that says child lock,,,press and hold for 3 seconds,,if this doesnt work un plug it for a minute..than replug
Posted on Dec 24, 2008
2 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Whirlpool Duet Dryer GEW9250P (electric)
Here is a list of possible causes. NONE OF THE LEDS LIGHT... Check to make sure that ribbon connectors P3 and P4 are inserted all the way into the machine control electronics board. (To access the machine control, pull the dryer away from the wall and remove the three screws from the top panel on the back. Slide the top panel rearward about 1/2" and lift. The machine control is on the left hand side. P3 and P4 are the "ribbon" connectors going into the board.) A PARTICULAR GROUP OF LEDS DOES NOT LIGHT... A group or combination of LEDs share a common electronic connection. If this connection is open, all of the LEDs in the group will be disabled. If this occurs, replace the entire console electronics and housing. ONE LED DOES NOT LIGHT... Press the button associated with the LED several times. If the LED does not light, the LED has failed. Replace the entire console electronics and housing. NO BEEP SOUNDS... If the associated LEDs do light up, the beeper circuit may have failed on the machine control electronics board. NO DRYER FUNCTION IS ACTIVATED WHEN A PARTICULAR PUSHBUTTON IS PRESSED... If the associated LEDs do light up, the machine control electronics board may have failed. AN E3 ERROR CODE IS DISPLAYED... An E3 error code means that there is a user interface or a software mismatch. It can also mean that a component on the console electronics,or the machine control electronics board has failed. Hope this little tutorial gets you where you need to go. Let us know how it turns out, will ya?
Posted on Sep 14, 2007
Control locked light is on? whirlpool duet dryer-mod GEW9250PW1.
Hi
Press and Hold the End of Cycle Signal button for 15 seconds, this will unlock the control. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Whirlpool GEW9250P Electric Dryer
I have a Whirlpool Duet dryer it is not heating everything else works
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Whirlpool GEW9250P Electric Dryer
Control lock is on on my dryer and it will not come on...
Press and Hold the end of cycle for 3 seconds. It will get unlocked
Feb 27, 2011 | Whirlpool GEW9250P Electric Dryer
I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
Oct 31, 2009 | Whirlpool GEW9250P Electric Dryer
Can I reverse the swing on my Whirlpool Duet Washer and dryer?
Yes they can be reversed. Some models require a kit with handles and trim pieces. Get the model# and I can try and look this up for you. Vic
Jun 28, 2009 | Whirlpool GEW9250P Electric Dryer
My Whirlpool Electric Duet Dryer (GEW9250PL1) will not cylce on when depressing the START Key. I hear a "relay-like" click. In diagnostic mode, when pressing Start I get 1 beep and a cod "08" on the...
It is most likely a blown thermal fuse. There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix. If you don't keep your lint filter cleaned out, you will likely get the overheating problem, causing your thermal fuse to blow.
Apr 06, 2009 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet Dryer has a mind of it's own, cannot change contro
First of all check to see that the control panel is not locked. There is a lock button assigned on the control panel. It should say it next to one of the buttons. Not door locked. You have to hold that button in for 5 - 10 seconds to unlock the panel. If not, you may need a new panel, happens often, its part # 8558753 depending on the color. Thanks Dave www.washermd.com
Dec 12, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer dead
you have no power to dryer ,,,, turn the breaker completely off, count to 30 and flip back on ,,, should work, if not replace the breaker
Jul 03, 2008 | Whirlpool GEW9250P Electric Dryer
Whirlpool GEW9250P Electric Dryer Logo
275 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
