Question about Creative Labs ZEN Vision:M Digital Media Player
Creative Zen Vision:M
My Zen has stopped working and is making a repeated clicking sound when I turn it on. I can reboot, it just says 'hard disk problem' Resetting it doens't work either. I've heard that I can try taking the battery out for a bit -but how do I get battery our of it?
I can't say this will work for you, but I had exactly the same problem (I think the clicking noise has something to do with the hard disk being slightly dislodged - possibly after dropping it?). I found that giving the side of the Zen a sharp smack on my knee sorted it out.
Posted on May 01, 2007
My creative zen micophoto will not boot up what do
Hi.
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
  1. Press on the Menu/Back button on your player, and select System, and then Reset.To Format or Clean Up Zen Vision:M Detach the Zen Vision:M player from your PC , and ensure that the unit is off.If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears: * Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)* Format All (Formats the players hard disk - Note: all contents will be lost)* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)* Reboot (Reboots the device)
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot
Good Luck^^
Nov 02, 2009 | Audio Players & Recorders
My creative zen screen wont light up its dark i tried the light up feature but no luck
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
hope this helps you
Jul 24, 2009 | Creative Labs ZEN Stone MP3 Player
Creative zen m vision won't start up,
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Freezing on the zen screen
This sounds like it might be a hard drive problem. Have you tried to put it into Recovery Mode so you can troubleshoot it? Put a paperclip in the Reset hole while holding the power button in the On position. Then release the paperclip and continue to hold the power button until it goes to the Recovery Mode screen. You should at this point try Format and Scan Disk/Cleanup, then Reboot. If it still gets stuck at the same spot, then its going to be a hardware failure.
Click here to view my step-by-step troubleshooting guide.
Click here to send in your device for free diagnostic testing.
Sep 06, 2008 | Creative Labs ZEN Vision:M Digital Media...
ZEN VISION M
This sounds like it might be a hard drive problem. To put it into Recovery Mode, do this: put a paperclip in the Reset hole while holding the power button in the On position. Then release the paperclip and continue to hold the power button until it goes to the Recovery Mode screen. You should at this point try Format and Scan Disk/Cleanup, then Reboot. If it still gets stuck at the same spot, then its going to be a hardware failure.
Sep 03, 2008 | Creative Labs ZEN Vision:M Digital Media...
Hard disk problem?
hi mark,I have same problem..recovery mode nothing works .. i live in australia and not sure yet who fixes it telss you about firmware download..have not tried yet..this is only something new.will try more things and post again Good luck Helen
Aug 04, 2008 | Creative Labs Zen Touch MP3 Player
Firmware problem for zen vision M
I had the same issue with my zen vision m. It was not recognized on any computer (although it would charge) and I noticed that when I turned it on after having it off for any amount of time, the zen would rebuild half way before turning on.
If this is what is happening with you, then this one solution I found to fix it:
Download the MP3 Recovery Tool from Creative Support website. Make sure that your Zen is charged at least half.   Turn on your Zen, Holding the power switch in the on position (Very Important!). While holding the Power switch on, Reset the Zen by inserting a small object in the Reset hole on the bottom of the Zen (small objects can include thumbtack, wire, earring, etc...). You will see a menu: Clean Up, Format, Reload OS/Firmware, Reboot. (It is now safe to stop holding the Power switch) I decided to go down the list until something worked.  I ran Clean Up first and that didn't work for me, so I tried Format.  It will remove all of your data. Once Format runs, Reboot the MP3 player and plug it up to the computer. Run MP3 Recovery Tool. The firmware should should install itself on your MP3. Once installed, your computer should recognize the Zen.
I hope this helps!
Jun 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
ZEN VISION M STUCK IN RECOVERY MODE
im having that sme problem! even when i try 2 restart it still acts crazy! when u find out how 2 fix ur let me kno cuz really want this thing 2 start workin again
Mar 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision: m does not load past the Logo screen.
After you turn on the player, put your ear up to the back side of it and keep listening for about 2 minutes. If the hard drive eventually stops spinning or makes a repeated clicking noise over and over in a repeated pattern then the hard drive is bad. It sounds to me like that is the case. You will need to get the hard drive replaced. You should take it to a technician, or you can also do it yourself, but be careful. The parts inside are delicate and easy to damage.
Sep 05, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
