Question about Averatec 3200 Notebook
Replacing Averatec 3200 keyboard
Hello - I have the new keyboard and looked at your instructions but my question is how do you open the mouse tracking section or just how do you open the keyboard to replace?
Thanks
  • Anonymous Dec 28, 2008
    Can you get replacement spaces that fit under the space bar? Mine broke on my Averatec 3200 laptop and now I have to use a plugin keyboard?
Mouse didn't detected
Touch pad usb or wireless mouse ?
Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs. Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time. Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard. Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse. This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function. Press and hold the "Fn" button together with the mouse icon button. Look for the disable/enable symbol that briefly displays on your screen. Slide your finger over the laptop's mouse and attempt to use it as normal. Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter." Press the left arrow key to navigate over to the "Device Settings" tab. Press the tab key to reach the "Enable" button in this section. Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box. Press the space bar to remove the check mark. Put your finger on the touchpad, and move the pointer down to the "Apply" button. Click "Apply" to save the settings. Close the mouse "Properties" box. Press the keyboard "Windows" logo key to open the "Start Menu." Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart." Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function. Open the "Control Panel." Go to the "Add and Remove" or "Uninstall" programs section. Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse. Select the "Uninstall" option to remove any software and settings associated with this secondary mouse. Restart your computer and attempt to use the built-in laptop mouse as normal. Check to see if the mouse is working properly. Press the keyboard's "Windows" button to open the "Start Menu." Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel." Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it. Find "Mice and other pointing devices from the list" and open its "Properties" dialog box. Select the "Driver" tab and choose "Update Driver." Allow Windows to search the Internet for drivers and to update them automatically. Restart your computer after the drivers are updated, and use your mouse as normal.
Beginners Guide to Using a Computer Mouse? Tips and Tricks
http://tips4pc.com/basics/beginners-guide-to-using-a-computer-mouse-tips-and-tricks.htm Laptop not working - touchpad unresponsive http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Apr 14, 2013 | Acer Computers & Internet
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
Can't open my optical wireless mouse to insert new batteries.
usually on the bottom of the mouse there is a little door with two notches or a single vertical notch which you need to carefully pry open and then insert your batteries as shown inside with + and - denotions.
Jul 29, 2009 | GE Wireless Optical Mouse
Mouse works very inter mittent using drag in
wireless mouse? Does it take batteries? Ps2 mouse? track ball mouse? Track mouse throw it away, go to the thrift store buy your self a new one or order a cheep wireless 1 on ebay.
Jul 24, 2009 | Logitech Computers & Internet
Got a new laptop, acer 6930, my old mouse worked until some updates were done, so i bought a new Logitech wirelesss mouse,, it says it installed it, but it doesnt work
if these updates are logitech based. may be issue with hid driver system.
  1. open the device manager
  2. look for the mouse section
  3. right click on the logitech mouse
  4. update driver (do not start auto updater)
  5. select advanced/install from specific location
  6. then select dont search i will choose a driver.
  7. if you see more then one logitech driver choose hid-compliant device.
  8. mouse should start working uninstall all logitech programs and delete all folders for logitech in the programs folder.
  9. use CCleaner to get rid of any registry entries.
Jul 16, 2009 | Logitech Cordless Mouse
Lost function on wireless mouse model kb990w
try to clean your mouse. Open and get the mouse track ball and try to remove the dust that may have accumulated on the bars holding the track ball.
Regards!
Jul 10, 2009 | Micro Innovations KB990W Keyboard and...
M/s mouse 3000 opens command window instead of executing icon
If you installed the software that came with it look in the program, and there will a section that assigns the buttons to specific tasks, it you can set them in there, and that should do the trick
Mar 31, 2009 | Microsoft Wireless Mobile Mouse 3000
My Logitech wireless mouse is not tracking consistently.
hello,have you tryed cleaning the bottom of your mouse any dirt of debre can cause a bad mouse curse movement also have you checked to make sure you have updated drivers for your logitech devises ?
Mar 31, 2009 | Logitech Wireless Access Duo Optical...
99039URF keyboard/mice track ball not working
I've got same problem at first time. After several trials, I could manage to work the whole unit by removing existing USB mouse. Just try to remove every input devices before connect it and follow the pairing instruction.
Good Luck!
Mar 28, 2009 | Btc 9039URF III Keyboard Trackball...
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Averatec 3200 Notebook Logo
446 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
