Question about Lexmark X5270 All-In-One InkJet Printer
Small printing on paper
I have a lexmark x5270 printer/scanner. It prints so small noone cal read it. How do I change the size of the lettering?? Thank you for your time..Beckyy
  • Janet Pickerd Apr 04, 2007
    Sorry but that was the wrong answer for me. On my printer, there is a button that sizes the type. My grandaughter was playing in the computer room and must of push to many buttons.. Thank you for your time
  • 22 Answers
It may be that you have the wrong printer driver. You can download the latest version at http://www.lexmark.com Also, you can check the printer as a standalone by using the menu and testing a configuration page. If it still prints small then it is in the printer. If not your computor may be the problem.
Posted on Mar 31, 2007
Lexmark printer won't print on bottom half inch of page
Make sure to set the correct paper size when printing. Letter - letter; legal - legal size.
Sep 21, 2012 | Lexmark Platinum Pro905 multifunction...
Lexmark T632 has 2 (ea) 500 sheet drawers, but once the paper runs out in Drawer 1 it will not automatically pull from Drawer 2. Please advise how to fix this problem.
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Feb 15, 2011 | Lexmark T632 Laser Printer
Printer printing text very small
1. On the computer:
- go on Print Preview, if document looks normal go to step 2. If it's small in Preview, read on.
- make sure you are writing in a font of at least size 10
- make sure you don't have ticked "Shrink to fit", but adjust to 100%.
- size of the paper is printing preferences is set up to A4 or Letter, depending on your region
- there is a known issue with Outlook printing in small font, you need a hotfix for that
2. On the printer:
- You have to go into the menu of the printer and see if there is an option for the font, if there is increase the size of it
- In the menu, make sure the paper size is correct
- If none of these worked, you may want to reinstall the drivers of the printer
- If that does not work, you may have to put a new firmware on the printer. You can download drivers and firmware from manufacturer's website
Dec 13, 2010 | Lexmark Z33 InkJet Printer
How do you adjust Fontsize on a Lexmark X5270 printer? In printing out emails the font size is VERY tiny I would like to have a larger font to make reading easier.
Actually, you can change the font size through the application you're using to make your emails. Try to explore the application settings before printing your emails. The Lexmark printer nor the printer software is not capable of changing the font size of your documents on your computer.
Jul 12, 2010 | Lexmark X5270 All-In-One InkJet Printer
Hello i have a lexmark t630 and when it prints out of tray 2 it says change tray two and beeps. It will work normal if you hit the select button. What could it be?
the printer is telling you that the tray is reporting the wrong size paper. print the network menu from tray 2 if it prints out smaller than the page it will be reporting smaller than letter. if the bottom line of the outline is missing its reporting legal size paper. if you are running lettersize paper in the tray check on the left side of the tray half way down the drawer you will see a plastic snap in plate with 3 fingers the bottom 2 should be sticking out for letter size paper. you only have to be one of the small adjust teeth off to make the third finger stick out and report the wrong size paper this is a very common issue. look at the metal fingers that stick out of the frame of the options tray to make sure they are uniform and straight. if the fingers are set right and not damaged then the logic board in the tray assembly will have to be replaced
May 14, 2010 | Lexmark T630 Laser Printer
Error message reads "34 short paper". What does this code mean and what can I do to correct it? Thanks
This error means that the type of paper that is configured in the printer is different from the one you have chosen in your computer to send for printing. Make sure that the paper size is the same in both places the computer program you are using and the printer. For example if I have a Letter size word document that I want to print but the printer has A4 configured then I will get the 34 short paper error but If I change the paper in the printer and the setting to letter size then everything should print fine.
Nov 13, 2009 | Lexmark C510 Laser Printer
Can't figure out how to print on statement sized paper.
After I had been attempting to adjust the paper guides in the feeder tray to accommodate statement-size paper, I finally "discovered" the drop-down door to the manual feed tray.  Duh!  This is a networked printer that I've only ever used for printing letter and legal sized documents until now.
May 28, 2009 | Lexmark T640 Laser Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
34 short paper
The printer does not auto detect your paper size and so when your Legal size document was printed on Letter size paper, you get a 34 Short Paper message.
Feb 07, 2009 | Lexmark C510 Laser Printer
Lexmark X5270 All-In-One InkJet Printer Logo
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
