Question about Nikon F65 35mm SLR Camera
Loaded film blank
I'm hoping u can tell me if I need to take my camera to the shop. I recently spent a Sunday afternoon taking pictures at an abandoned site and used about 3 rolls of film. I dropped the 3 rolls off to be developed and only one roll had pictures on it. The oter 2 were completely blank as if they were never loaded. I'm confused b/c the film was not loaded only by myself, so I'm thinking its not user error :-)
Any suggestions??
    Problem Solver:
  • 6 Answers
Next time when load film be more careful you will be fine.
There must be a sign to align the end of the film leader with this mark somewhere near the take up reel. That is the key!
Posted on Jan 01, 2009
    Scholar:
  • 95 Answers
Chances are the film had quite a bit of curl to it (often a sign of old film) and it was not pulled over quite far enough during auto loading, or perhaps too far and it had too much slack that the take up reel never grabbed it to advance it thru. You're not the first one this has happened to as the auto load is not as reliable as the older style where you had to load the film leader through a slot in the take up reel.
Posted on Dec 28, 2008
What does the E mean on the screen.I put a new film in at Xmas time and only took a few pictures when the E showed up and couldn't click the picture. took to camera shop replaced batteries and film ...
If you go to http://www.pentaximaging.com/support/manuals-and-literature/ you can find the manual for your camera. From my experience the E on a Pentax camera means the film isn't loaded properly. Hope this helps.
May 11, 2011 | Pentax Photography
Hi there, i recently purchased a polaroid 600 camera from ebay and some 600 film. However, when I try to shoot, I just get blank pictures coming out (completely brown - alomst negative-type look). I'm not...
More than likely, the camera is ok. It sounds like the film is either expired, or the previous owner did not store the film properly, therefore it cannot be exposed properly. If you bought it off of ebay, you do not know how the previous owner took care of the film. To narrow this problem down, I would get new film and try it again, hopefully this will work, but if not, it will further your troubleshooting efforts.
Mar 15, 2011 | Polaroid Cameras
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
I have a problem. I have taken several rolls of film, after they are developed there is no pictures,just blank negatives,what might be the problem and how do I get it fixed?
If you can see the frame numbers on the edge of the unexposed negatives, the problem is most likely either the camera's shutter is not opening, or the camera's take-up/advance mechanism isn't working properly. It could also be that the film isn't being loaded correctly. Check all three, or have a camera shop (not department store!) check it out for you. They should be able to test the first two situations easily, and help you if it's a loading problem.
Sep 27, 2009 | Canon EOS Rebel 2000 35mm SLR Camera
Loud grinding noise when I "****" the film.
kyle_walsh,
does this noise happen with film loaded or all the time?
this could be a broken gear or the take-up spool is slipping. with the film door opened advance the lever and check if the take up spool is turning. if not turning then a gear is broken. if the spool is turning then the spool is slipping.
there are no new parts available for the K1000, however some camera repair shops have good used parts that can be used.
the take-up spool was one of the very few weak parts of the K1000, you can make a temp. repair if you want.
on the take-up spool push down lightly on the gear like wheel and rotate the spool you should see a hairline crack under where the film is inserted. check both sides. if you find the crack put a very small amount of super glue on the crack using a tooth pick or similar tool. this works 80% of the time.
if you take or send your K1000 to a camera repair shop get an estimate first.
Feb 23, 2009 | Pentax K1000 35mm SLR Camera
Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Jan 25, 2009 | Nikon N90S 35mm SLR Camera
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Not taking Pictures
The camera needs to be loaded with film.
Needs new battery
Apr 02, 2008 | Canon Prima BF-80 35mm Point and Shoot...
Pictures did not take
Check for the settings of the camera .Open the back door of the camera now press the button seeing through back, if the shutter opens up and closes everything is correct.
check for the film.
Apr 01, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Film not loading properly
The lines could be scratches in the negatives.
Have you looked CLOSELY at your negatives with a magnifier to see if the scratches are on your film?
And when you say "Serviced", do you mean "cleaned" also?
If you have scratched film, then return it to the place you got it serviced/cleaned and let the owner/manager know that you just had it serviced there and it's scratching your negatives.
If you have an automatic camera, this bit below will be of no help.
Assuming that your camera is a manual loader, it may be that you aren't putting enough film into the take up spool for it to catch.
Try putting a little more film into the take up spool when you are loading the camera, and MAKE SURE that the holes in the film LINE UP with the film sprockets.
Then after you close the film door and start advancing your film, look at the film rewind knob, if it isn't turning while you are winding in film, then your film hasn't caught in the take up spool.
Another way to tell if your film is advancing is to shoot a test shot, and then advance the film, and then lightly turn the rewind knob a bit.
You should be able to feel the tension of the film if it is loaded correctly.
Feb 13, 2008 | Nikon FM10 35mm SLR Camera
Nikon F65 35mm SLR Camera Logo
202 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
