Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Icemaker I have an Amana refrigerator model# HMG191450. The ice maker worked fine until I moved into my new house. Once I moved it stopped making enough ice and what it did make was often hollow. I have since replace the water-inlet valve and the ice maker itself and the results have not improved. The water flow to the ice maker is good but for some reason since I've moved here, the two or three ice slots (out of eight)closest to the door do not get water so they make no ice. The fridge is level and I moved within the same city so the water is the same. I have tried the freezer set at all the different temperature settings but the results are the same. I am completely perplexed and would appreciate any help.
  • Anonymous Jul 14, 2008
    I HAVE ADRMIAL REF. MODEL ASD2514AR WORK GREAT UNTIL I MOVED JUST AROUND THE CORNER INTO OUR NEW HOUSE THE FRI. IS ABOUT 5 YEARS OLD . IS THERE A FILTER INLINE SOMEWHERE ? PLEASE HELP BECAUSE WE LOVE ICE. I'VE CHECKED THE LINE ,WATER PRESSURE ,SWITCH I JUST DON'T KNOW THE FRI. IS 5 FOOT FROM WATER SUPPLY IT'S COMING STRAIGHT FROM WATER HEATER.
I put a meter to the ice maker and got a 118.5 reading so it is good. I did not get the spitting you were talking about. The plastic screw broke when I turned it counter-clockwise. When I turned it clockwise it just raised the lever that tells you when the tray is full (it was already set as far clockwise as it would go). When I turned it counter-clockwise it turned a little and then the two plastic prongs broke off. I can't believe that is what they are made of. I was gentle with it and they still broke. No wonder everybody is sick of American products. Luckily I saved my old ice maker and swithced out the face plate (for lack of a better term). The water lines are clear. If I take the line off the back of the freezer, water will shoot out but it does seem like my problem is getting enough water and I am out of ideas. Thanks for your help. I'll take any other suggestions you might have.
Posted on Apr 30, 2007
    President:
  • 878 Answers
Bruce I can see why you are perplexed, seems you covered all the basis. By your post, it sounds like you are loosing pressure somewhere. Take the cover off the ice maker module. You will see test points L
Posted on Apr 14, 2007
  • 1 more comment
  • Ron Marek
    Ron Marek Apr 14, 2007
    Test points L&V, will send 120 volts to the valve. See if you are spitting any air while testing the fill. On the right side of the module there is a small plastic adjusting screw. Clockwise will decrease the fill, counter clockwise will increase the fill. Try this first and post back...Catriver
  • Ron Marek
    Look for any pinched lines in back and obstructions in the fill tube itself.
  • Ron Marek
    Ron Marek Apr 30, 2007
    Bruce, In the picture I sent you do you see the small plastic adjuster on the right hand side edge? right in the middle on the edge. This is the water adjustment screw. By your second post it sounds like you were turning the shut off lever. What I wanted you to do is take a jumper wire and jump L & V. Just like in the picture. I was not concerned about the proper voltage. This would send 120V directly to the water valve and water should be comming out of that fill spout as long as you are jumping L&V. This was to insure that there was no air in the lines. The minimun pressure to that fill valve should be 30 psi. in order for that valve to open and seat properly. You might have to put together a guage and check it. Catriver..post back.
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Amana model tg21vl stops making ice
    pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
    Feb 24, 2013 | Refrigerators
    Ice maker stopped working on bottom freezer amana. Is there a reset button?
    There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
    Replacement parts can be purchased at any of the following web sites:
    searspartsdirect.com
    pcappliancerepair.com
    appliancepartspros.com
    repairclinic.com
    partsselect.com
    Before going to buy any parts directly.
    Go through this troubleshooting help links.
    This is list of refrigerator problems, which is normally faced in refrigerator.
    You can go through the details, by clicking the link below:---
    Refrigerator is not cooling properly?
    http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
    Both refrigerator and freezer not cooling properly in refrigerator?
    http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
    The ice maker not working: ---
    http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
    Compressor not running on refrigerator?
    http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
    Water dispenser not working on refrigerator?
    http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
    Ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
    Water Overflows in Ice maker and freezes inside?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
    How to replace Ice maker assembly?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
    These will help.
    Thanks,.
    Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
    My icemaker is not working... we had to disconnect the refrigerator to move it and the ice maker has not worked since we plugged it back in..
    You may need to re-jump the ice-maker, with a jumper wire to get it to start, some ice-makers need this. You'll just get a piece of coated wire, with both ends twisted. There should be two holes by the ice-maker gear, stick both ends of the wire into each hole. This should re-start the ice-maker, leave it in, until the ice-maker gear starts moving by itself. You may or may not, need to hold the freezer door button in.
    Mar 29, 2010 | Amana 22.6 cu. ft. Side-By-Side...
    Testing IM-6 Water inlet valve
    check water valve or icemaker
    Apr 06, 2009 | GE Refrigerators
    Freezer not making ice in Fridgidaire model PLH269ZDB2
    There is a lever in the ice bin that detects when it is full. if that lever is locked in the"up" position, the maker stops making ice. Many times a previous owner or a shipper will turn off the icemaker this way. especially if the water to the home or freezer is turned off, so it won't keep trying to make ice.
    Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
    11 year old amana bottom freezer icemaker drips water when filling tray
    Hello dunc444444
    Welcome,
    You said, Bottom freezer works fine, but upper refrigerator has no cold air
    Is your freezer so full that it is packed to the top especially in the rear?
    Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
    Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
    The water overfilling in the ice maker is an ice maker problem only.
    When we install an ice maker there is a short white plastic tube that we push through the rear
    hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
    That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
    rolled the fridge out to clean under it!
    Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
    The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
    Let me know how you do?
    Huuum {
    Let me know.
    Huuum
    Please remember to leave a rating.
    Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
    Kenmore Bottom Freezer 596.71103101 Ice maker not working right
    Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
    Nov 13, 2007 | Refrigerators
    Freezer Problem
    The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
    Oct 04, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
    RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
    press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
    Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
    Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
    184 people viewed this question
    Top Admiral Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
