Question about Epson Stylus C86 InkJet Printer
How do you
Is there a way to remove the print head for cleaning? This printer had been sitting for quite sometime; thusly it had probably dried quite a bit...
  • bronaugh Dec 27, 2008
    printer has not been use for long time
  • 353 Answers
Hi BRONAUGH
Can you let me know what you have tried. Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If these actions produce no positive results, or you have any queries about my advice, please report back with a new comment.
If this advice has been of help, please rate it.
Posted on Feb 15, 2009
Unable to clean
Do you mean the automatic cleaning option the printer has? Does the printer have a removable print head? If so, you must remove the print head and clean it by letting it sit in a bath of rubbing alcohol or running cold water into it for several minutes. Let dry and reinstall. Or you may need to replace the print head. The nozzles are probably clogged. Does the print job seem abnormal?
Apr 02, 2013 | Brother MFC 210C All-In-One InkJet Printer
My Canon won't clean its print heads
Have you tried power cycling the printer?
Feb 17, 2008 | Canon i860 InkJet Photo Printer
I960 won't print despite new print head
Hello!!
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
Feb 08, 2008 | Canon I960 InkJet Photo Printer
SeeTroubleschooting and Routine Maintenace chapter in user's quite.see clean unable 51 to MFC-230C
Hello and Welcome to FixYa!
"Unable 51" is most likely a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Your problem will be solved.
For any further help, you can take my valuable,professional help by taking my Service
Thank You for using FixYa
Mar 02, 2012 | Brother MFC-230c Printer
Message : 'unable to clean' have replaced cartridges and put old ones back but to no effect.I have not used the machine for a long time
If printer has been sitting for a long time the problem is probably due to a clogged print head. Ink residue can dry in the print head and clog the ports. Replacing the print head can be as expensive as a new printer. Before running out for a new printer do a web search for 'print head cleaning'. There are several sites that provide detailed step by step instructions for cleaning most print heads. To prevent this in the future; print a tet sheet at least once or twice a week or, if your orinter will be idkle for a extended time, remove the cardridges a seal them in an air tight container.
Jun 13, 2011 | Office Equipment & Supplies
My printer won't print anything - only blank pages. However, both ink cartridges have ink. Please help!
If the self-cleaning cycle does not solve the problem, try turning the printer off overnight to allow the ink to soften. Turn the printer on the next day and try printing a test pattern to see whether the problem has either disappeared or become less noticeable. This ink-saving procedure can work effectively because sometimes the dried ink on the print head needs time to soften before the printer head can be cleaned completely. Try running the self-cleaning utility again one or more times.
Steps for Manually Cleaning the Printer Head
If the overnight cleaning still does not work, there may be a layer of thick ink that is blocking the holes of the printer's head. The next option is to manually clean the printer head. Follow these steps:
* Determine from the owner's manual where the print head is located.
* Remove the ink cartridge from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. NOTE: Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets, and if you get isopropyl alcohol on the gaskets it could dry them out.
* For models where the print head is in the printer, drop 7 to 10 drops of isopropyl alcohol (91% denatured isopropyl alcohol - not 'rubbing' alcohol) down the ink receptacle area where the ink actually flows from the cartridge into the head. Run a few self-cleaning utilities. If possible, allow the printer to sit a few hours or overnight and repeat the self-cleaning utility.
* If the print head is in the cartridge, soak the cartridge print head in hot water. Allow it to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
* If the hot water soak did not unclog the print head, place the cartridge printer head in isopropyl alcohol and allow it to soak overnight. Use a damp paper towel to wipe off the print head area and dry carefully. Try the self-cleaning utility again.
* If the alcohol soak did not unclog the print head in the cartridge you may need to purchase a new cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the printer head.
Jun 09, 2010 | HP DeskJet 5150 InkJet Printer
Printer is printing lightly even with head distance adjustment set to H. An idential printer prints normally at that setting.
It could be caused by quite a few things some of which only a printer technician could see and fix.
I have however provided some information below which I hope is of use.
There is a strong chance that the ribbon is drying out.
If the printer is in a hot dry area this would certainly cause this type of problem.
Another possible cause is that the print head is becoming worn. Dot matrix printers use tiny solenoids to pus a pin forward against the ribbon. this happens many thousands of times over the printers life.
If it has to do multipart stationary this puts added pressure on the head.
Yet another cause is clogging of the head. Quite a few years ago people use to use such as WD40 to extend the ribbon life and to some degree this worked but had a negative effect on the head. To much ink and moisture can clog those tiny solenoids or build up around them.
Isopropynol on a cotton bus is about the best option for cleaning a head but you always have to make sure that none of the cotton but is left on the head. clean it repeatedly until your cotton bud no longer shows signs of ink and as soon as that is the case run a few sheets of heavy printing through it to check the results.
If using multipart then the roller that the paper sits against can also become worn. Sometimes this is not even noticeable.
It is still possible to get new heads for many dot matrix printers but they are getting harder to find.
Aug 25, 2009 | Panasonic KX-P2023 Matrix Printer
How do i clean printer head on cannoni560s
I assume you've done the clean/deep clean routine.
First, check that dirty heads are actually the problem and not bad contacts at the back of the print head carrier. Remove the ink tanks (keep them upright on a piece of plastic or a paper towel) and then flip up the grey carrier retainer. The print head carrier will lift out easily. Take care - don't damage the print heads - they're very fragile!
At the back of the carrier you'll see a series of gold contacts. Clean them carefully with a soft cloth and isopropyl alcohol. Now look at the pint heads themselves. If there's dry, gunky ink on them they will need cleaning. The simplest way is to stand them in a saucer of Windex glass cleaner overnight, then rub them gently with a soft cloth or paper towel. I'm recommending Windex only because I know it works. Other products might be just as good but I don't know.
Now put the print head right-way-up on a clean paper towel and drip a drop or two of alcohol onto each of the four round metal contact plates that sit under the ink tanks. After a minute or two you should see a colored pattern on the paper - black, blue, red and yellow, corresponding to the shape of the print heads. This means that the print heads will pass ink through from the tanks and further cleaning shouldn't be necessary.
Now reinstall the print heads and replace the ink tanks. Do a deep clean to get the ink flowing again, and run a test print. It'll probably be okay. If not, leave the printer to sit for 12-24 hours then try again.
If you don't get a good test pattern, especially after a couple more cleanings, you probably have a damaged print head. You'll have to replace it. If you're lucky, you'll find one on the web that costs you less than you paid for the printer.
If the printer refuses to print at all, you have other problems, most likely a full waste tank or, worst case, a blown circuit board. You're facing a trip to your local repair center.
The i560 is a fabulous printer (which is probably why Canon discontinued it). It's worth spending some money to keep it going.
pra
Aug 08, 2009 | Canon BubbleJet i560 InkJet Printer
Canon Pixma IP5000 wont print cyan or magenta
Think you need to clean the sponge that the ink cartridges sit on in the head tray they are probably blocked with dry ink. You can remove the print head and tray by lifting the lever and gently lifting it out..... go here http://www.inkjethelper.com/
to see how to carefully clean it with compressed air. I had to do this too.
Apr 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
I can't get my black ink to print.
Could be the ink dried up. Unusual but happens sometimes. If you shake it does it sound like liquid in it?
If you recently replaced the cartridge, did you remember to take the tape off? (I know, sounds silly, but sometimes it happens.)
In the software, does it register that there's a blank ink cartridge installed?
Just a couple of ideas to get you going. Respond back and I'll work more with you.
Apr 07, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus C86 InkJet Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
