Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Dyson dc17 hard to push
My dyson dc17 all of a sudden became almost impossible to push across carpet. any solutions?
SOURCE: Dyson suddenly hard to push on carpet
If the brushes are turning, you may need to clean the brush of any hair or anything else that has collected on the brush. If you have been cleaning it regularly,
Posted on Jun 08, 2008
SOURCE: dyson dc17 animal
on the bottom plate are 3 spots, one in the center and one at each corner, that need a flat head screw driver to loosen. turn left to unlock, this will remove the plate so you can clear the debris from the brush.
Posted on Feb 01, 2009
SOURCE: How to replace belt on Dyson DC17
Preface: Dyson folks were great, answer so simple I was embarassed after I called. 5 minute fix.
1. Loosen 3 screws from bottom plate using flathead screwdriver or coin edge and remove it.
2. Wiggle roller until it pulls straight out.
3. Squeeze new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
Posted on Apr 04, 2009
  • 389 Answers
SOURCE: My dyson vacumn is hard to push on carpeting. How do i fix it?
This happens when the bristles in the brush roll get worn down too short. Put in a new brush roll and the machine will pull itself over the carpet, so you hardly have to push at all.
Posted on May 19, 2009
  • 97 Answers
SOURCE: dyson - can't push the vacuum
try to see if the carpet setting is to carpet. i know this machine says that its a life time belt,but i would check this just in case. best way to tell if it's working is to lay the machine on its belly with the brushes pointing up and turn on the machine to see if the brushes are turning. (be careful not to put your face directly in front, just in case something is lodged in the brush and flies out )
Posted on Jul 29, 2009
How do I make the machine easier to push forward ?
Dyson will tell you to remove the gaskets from the cleaning head. I have 2 Dysons, both of which became impossible to push after new carpet was installed. I was skeptical, but it worked.
Nov 29, 2015 | Dyson DC14 Animal Bagless Upright Cyclonic...
Why does my Dyson DC17 now push really ******* carpet?
Have you correctly replaced the glider that covers the brush? You need to make sure that the clips are fully seated .
Aug 16, 2014 | Dyson DC17 Animal Upright Vacuum...
Extremely difficult pushing vacuum over new carpet
Hi Julie,
I'm sorry to hear you're having difficulty using your DC17 on this particular carpet type. I'd encourage you to contact the carpeting manufacturer for advice, as they should be able to recommend the best way of cleaning it.
If you'd like any further assistance with your machine, please email us on askdysonUS@dyson.com, or give our customer Helpline a call on 1-866-693-9766.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 09, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Very hard to push. It started gradually but now its nearly impossible to vacuum the carpet. Is this an easy fix?
I'm sorry to hear you're having difficulties with your DC17. If the cleaner seems more difficult than usual to push, it's a good idea to check the soleplate for damage, and to remove any threads, hair and other obstructions from the brushbar. The easiest way to do this is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=961&product=DC17-ANIMAL
You may also want to contact your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brushbar. Manufacturers sometimes recommend cleaning certain types of carpeting using suction only.
If you have any further questions or concerns, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Aug 24, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson dc17 will not roll across the carpet, because their is too much suction.?
Turn on the beater bar with the gray button next to the red power button. The powered beater bar will "propel" the vacuum across the carpet.
May 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
When pushing foreward the vacuum is hard to push and if pushed on to hard it will turn over on itself.
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.
Sep 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
May 19, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Jun 02, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
314 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
