Question about Canon NP 6551 Black and White Copier
Canon Np 6551 e502
THere is no paper anywhere , main board has been replaced
completely disassembled no signs of abnormality or broken parts
  • Anonymous Mar 18, 2014
    load canon np 6551 staples
  • 168 Answers
That error is a communication error between the copier and the sorter unplug the sorter then turn the copier on should go away. probably loose connector or bad sorter board
Posted on Dec 19, 2008
Errour 000
E000 The fixing temperature fails to increase.
Disassemble fuser and inspect thermistor, thermostat and heat lamp, then replace broken part.
Feb 01, 2011 | Canon NP 6551 Black and White Copier
I have a copy machine the model is canon np 6551 and on the screen there is a message E005 switch the power on and off again what should I do?
it is code for cleaning web. the fuser cleaning web may have tqken up completely if so, replace it. else check sensors which detect taken up cleaning web.
Jan 28, 2011 | Canon NP 6551 Black and White Copier
Canon 6551 copier-rollers are grabbing causing smear on the copy
check the paper path you need to control the main drive mecanism, and all bushing roller : registration roller, pickup, fixing and exit: you can see exemple of the bushing to check: mabroukmedal_41.jpg
the roller that you need to check and replace the bushing:
Dec 21, 2010 | Canon NP 6551 Black and White Copier
I have an E0 code
Check the main thermistor,the thermal switch,the heater lamp.This components it is in open circuit.Reset the error code in service mode.
Sep 27, 2009 | Canon NP 6551 Black and White Copier
Canon NP 6551 When putting paper in the
a sensor in the adfeeder could be contaminated by dust if you have the blower try to blow the whole feeder unit check also if there a two tongue like black plastic that is coming out on top of the originals when pressing the start button.if this thing will not come out the machine will tell you to put the originl again
Jun 29, 2009 | Canon NP 6551 Black and White Copier
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Feb 17, 2009 | Canon NP 6551 Black and White Copier
Jamming paper
you have to replace paper pick up roller set
Dec 14, 2008 | Canon NP 6551 Black and White Copier
Canon 6025
"E001" Abnormal fuser temp. (thermistor, dc controller, ac driver)
Nov 17, 2007 | Canon NP 6551 Black and White Copier
Canon NP 6551 Black and White Copier Logo
141 people viewed this question
old marine
old marine
