Question about Philips 43P8341 43" Rear Projection Television
Front panel removal instructions for
Helo, I am needing to replace the plastic screen that protects the display in my Phillips 43P8341. I have removed all of the screws that I can find associated with the front panel but it will not release. I can tilt the top of the panel down and see inside, but I cannot seem to get it to let go. Is there instructions that I can follow to remove the panel successfully without damaging the plastic tabs? Thanks, Richard
You have to remove the back bottom skirt from television in order to get to the screws for the front bottom panel. When the front bottom panel is removed there will be more screws visible, for front screen. After an afternoon of trying to get it apart, just to clean the mirror on ours, we finally got it.
Posted on Nov 23, 2007
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
Black screen delld600
Several things can cause your Dell Latittude D600 laptop's LCD screen to stop working.
Two of the most common causes relate directly to the inverter board and the backlight lamp.
The inverter board is a thin circuit board placed inside the LCD panel.
It's main function is to transfer power from the motherboard to the backlight bulb inside the LCD screen.
If the inverter board goes bad or the backlight lamp burns out, the screen will appear dim or eventually go completely black.
Turn off the laptop, unplug the power cable, close the LCD panel and place the laptop face down.
Remove the battery pack from its compartment on the bottom of the computer.
Flip the laptop back over and reopen the display panel all the way until it is in a 180-degree position.
Insert a flat head screwdriver into the right side of the keyboard bezel.
This is the plastic strip situated above the top row of keyboard keys. Carefully pry the bezel from the laptop.
Remove the two Phillips screws located above the top row of keyboard keys.
Grasp the top edge of the keyboard, tilt it upward and lay the keyboard face down on the palm rest area.
Unplug the keyboard's ribbon cable from the motherboard connector.
Carefully remove the entire keyboard from the laptop.
Disconnect the video and speaker cables extending from either side of the LCD panel to the motherboard.
Loosen the Phillips head screws on each LCD panel hinge.
Carefully lift the entire LCD panel off the laptop's base.
Relocate the panel to a flat work surface, and place the panel so the screen is facing upward.
Use a thin, flat head screwdriver to pry the rubber screw covers from the LCD panel's front plastic cover.
Remove the Phillips head screws revealed by the rubber covers.
Carefully remove the front plastic cover from the display panel.
Locate the inverter board situated below the LCD screen, inside the bottom edge of the display panel.
Disconnect the two cables from each end of the inverter.
Remove the two Phillips head screws fastening the inverter to the display panel.
Carefully lift the inverter board out of the display panel, and dispose of it.
Repeat this procedure in reverse to install the new inverter board, and reassemble the laptop.
Hope this helps
Oct 23, 2012 | Dell Latitude D600 Notebook
How do you remove display panel from frigidaire affinity washer
Pull out the detergent drawer, pressing the catch button in the rear of the drawer. There are a couple phillips screws through the panel around the drawer. Take those out. The display panel (including the entire plastic piece) is attached by plastic clips. Unsnap them by applying firm, controlled pressure along the top and sides of the plastic panel. Should come right out for you.
Feb 20, 2011 | Frigidaire Affinity ATF7000ES Front Load...
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
Loud humming sound while drying, need instructions on disassembly to properly diagnose
Disconnect power to dryer. Open door, remove phillips screw from 4 and 8 O'Clock positions, close door. Use putty knife (preferably a plastic one to prevent scratching) to push in the two clips holding the top to the front panel, then swing the top back, revealing the phillips screws holding the front panel onto the body of the dryer. Remove them and un-hook door switch and drum light connections, allowing total removal of dryer front panel. Remove 4 phillips head screws retaining front drum support and lift it up just a bit to remove it. Reach back under drum to the left side to release belt, allowing drum to come out of dryer.
Jan 29, 2010 | LG DLE2532W Electric Dryer
How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
Here it is! Have fun!
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery2_bing.gif.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  5. Place the wireless LAN Minicard in a static dissipative bag.
Before you begin: Remove the battery.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
We have a hp pavillion dv7-1240us & we need directions on how to replace the screen ???
LCD Panel removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery, wireless LAN Minicard, keyboard, switch cover, display panel, display bezel, and inverter.
    Important! Use care when disconnecting the wireless antenna cables from the wireless LAN Minicard. Damaged cables or connectors can degrade notebook performance.
    Note: If three antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to terminal 1, the cable labeled 2 connects to terminal 2, and the cable labeled 3 connects to terminal 3. If two antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to the MAIN terminal and the cable labeled 2 connects to the AUX terminal.
  4. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  6. Place the wireless LAN Minicard in a static dissipative bag.
Keyboard removal Caution! Observe all precautions when removing and replacing components.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
    Important! Use care to prevent damaging the keyboard ribbon cable.
May 17, 2009 | HP Computers & Internet
AOC lm929 monitor
AOC LM929 or Envision EN-7100 removal instructions:
DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
with a small flat head screwdriver, insert into the edge and pop open the small plastic
pieces that surround where the stand connects to the monitor. put plastic pieces aside.
lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
remove 4 screws in the center that hold on the stand. put stand and screws aside.
lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
side edge of the grey plastic and turn screw driver so the plastic surrounding the
screen edge pops up exposing an area surrounding the screen. put plastic rectangle
piece aside.
slide out plastic buttons piece from the side and put aside.
with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
the screen assembly to the back housing. now lift screen assembly out of the plastic
housing. put back plastic housing and screws aside AND lay the monitor screen with the
FRONT side down on a flat soft surface.
with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
cover. slide the cover down and remove. put the cover and screws aside.
USE CAUTION!!! Some components may still contain a charge.
check fuse... whatever...
Aug 29, 2008 | Computers & Internet
Phillips 43P8341 no picture, blinking red light
Goto www.magnavoxhelp.com. They have a kit that will fix this common problem.
May 17, 2008 | Philips 43P8341 43" Rear Projection...
Philips 43P8341 43" Rear Projection Television Logo
434 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
