Question about Garmin Nuvi 660 GPS Receiver
After 2 - 10 Minutes Satellite connection is lost
When I switch my 670 on it finds the satellites and works fine once I begin to move it switches to Acquiring satellites and the ? symbol appears. If I switch to the satellite indicator it shown no connection. If I then switch it off and on again it occasionally works OK for another 2 - 10 minutes. I have tried a re boot but it has no effect.
    Scholar:
  • 40 Answers
Try this and see if it fixes your problem....first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
Posted on Jan 03, 2009
Garmin gps 60 can not locate satellite
When you turned it on in the hotel, it is not the Garmin. But if you were outside and could see the clear sky, and the GPS evice did not find the satellites within 2 minutes there could be something wrong.
When you switch of an GPS in one place and you switch it on, on a completely different place, it can take a while till it found enough satellites to make up where it is.
But two minutes should do the trick. Don't try this somewhere inside or close to buildings or trees. The device should have a clear "view" to the satellites above the equator.
Aug 02, 2014 | Garmin 60 GPS Receiver
I have a ifinder hunt GPS, it will not locate any satellites, it then prompts me to stop searching or continue to search for satellites. I have been trying this device over the last 10 months, mostly on...
With a normal GPS device, when you first switch it on, it needs some time to locate enough satelites. Most of the time it needs at least 5 satelites. Some time should be like minutes and not hours. After the GPS device fond enough satelites, it knows where it is and can when it is switched on again work faster. When you try to let the GPS search for satelites indoors, or without a free view to the sky, it is possible the receiver never can find satelites at all.
I don't know if any test of the Lowrance iFINDER Hunt GPS was placed on the net, but that is where you can check how long it should take for the GPS to find enough satelites.
Oct 30, 2013 | Lowrance iFINDER Hunt GPS Receiver
My satellite is on 129 and 119 and I want 119 and 110. I have move skew, height , and azimith with no luck. I can always get back to 129 and 119. Does the satellite default to these numbers once check...
How many coax cables are you using from your dish, 1 or 2? Do you have a switch between the dish and receivers? I am assuming your have a 1000.2 dish since you say you have the 129, 119, 110. On the LNB you have 4 coax ports. Facing the LNB, the port on the far left is for 119, the next is 110, then 129, and that last on the far right is for an additional dish. If you want to get 119 and 110, just use the 2 ports on the left. Once connected, run your check switch. I hope this helps.
Jun 27, 2011 | RCA DISH Network(r) 311 Satellite System
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
Im trying to find how to rebot my laptop back to factory its a toshiba satellite m35-s320
Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
  • 2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
  • 3) When the machine Starts beeping; release the 0 key.
  • 4) When prompted by the warning screen; select Yes to continue with the system recovery.
  • 5) Select Recovery of Factory Default Software; click Next.
  • 6) Select Recover to out-of-box state. Click Next again.
  • 7) Click Next to Start recovery.
May 18, 2010 | Toshiba Satellite M35-S320 Notebook
Hi!, thanks for helping me Toshiba laptop satellite a135-s7402, what's the key to run the recovery at start?
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Thanks,
Viju
Apr 06, 2010 | Toshiba Satellite A135-S2326 Notebook
Lost Satellite reception
If its raining, that will cause you to lose satellite reception.
If that is not the problem, then do this: turn off TV & satellite. Wait 5 minutes. Power back on. Most of time this will fix it by itself.
If neither of those do it, unattach your satellite cable from back of satellite box. Power everything off. Wait 5 minutes. Now reattach your satellite cable. Power everything on. It should search for you sat and find it. Let me know if this works.
If none of those work, then I would call the sat company for help.
Jul 07, 2008 | GPS
Unable to acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} My Gamin Nuvi 660 Solution
External antenna - Garmin 25MCX low profile remote GPS antenna
I have been experiencing the same problem many have been having with the Nuvi 6xx and 3xx series giving an error message “Lost satellite reception”.
My problem started mid April 2008 and got progressively worse. I would use my GPS on weekends and it would work perfectly for the first 10 – 30 minutes and then would loose satellite reception, rendering it useless.
I bought my Nuvi 660 when it first came out in October 2006 for just under $700 and is now out of the 1 year warrantee.
I called Garmin Technical Support and we checked my Software version (4.40) and more importantly my GPS SW version (3.00). According to the tech I had on the phone, the GPS SW version was more important then the Software version. It was in fact already updated to 3.00, I did master reset, after master reset, but regardless, nothing helped.
I contemplated what I should do.
Return mine and get a refurbished unit from Garmin for $225 with only a 90 day warrantee?
Buy a new Nuvi 660 for around $300
Buy a new Nuvi 2xx series with fewer features for $200 to $275.
Buy a Megellian GPS?
I read through this forum and came across one person that was told by Garmin “that they are aware of an issue with some Nuvis involving the failure of a diode in the unit that senses whether or not an external antenna is connected.” Apparently this diode failure is caused from the high heat these units experience from being left in a hot car for long periods of time. This would explain why mine would work in the beginning and then die.
So my thinking was, if the diode “thinks” there is an external antenna attached when it isn’t, what would happen if I “did” connect an external antenna?
Garmin recommends the Garmin GA 25MCX low profile remote GPS antenna for the Nuvi 660 and costs $31.49 (not sure about additional costs for tax and shipping)
So I purchased the NEW antenna from a seller on eBay for $25.90 total and IT WORK FLAWLESSLY.
Just to make sure it really was the new external antenna that was working and not the unit coming back to life, I started my 3 hour journey with the external antenna NOT connected. As usual it lost satellite reception in about 15 minutes. I plugged in the GA 25MCX and it immediately connected to the satellites and never lost them.
I repeated the same process coming home and once again, I connecting the external antenna after the unit reported loosing satellite reception, and it worked perfectly.
Conclusion: if your unit is experiencing loosing satellite reception, and is under warrantee, return it ASAP. If it’s out of warrantee, get an external antenna. There are other manufactures of external antennas and all should work as long as it has an MCX connector.
Side Note: This external antenna also worked perfectly on a friend’s Nuvi 350 with the same problem.
I wanted to share this with everyone because I’ve been racking my brain for months over this. I hope this helps.
May 04, 2008 | GPS
Dish network 119
you cannot satellite sginal from a splitter you will need dp 34 switch or quad LNBF DP HOPE THIS HELPS.
Jan 12, 2008 | RCA DISH Network(r) 311 Satellite System
Garmin Nuvi 660 GPS Receiver Logo
112 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
