Question about Hitachi C21RF39 21" TV
Hitachi C2166 TN Television
Code which reads C46TN has appeared in the middle of my TV screen. I believe that this is a servicing mode but I have no idea to get rid of it. I am sure that a combination of button pushes will exit it out but I have no idea what they are any help would be appreciated.
Using the handset, press the two record buttons together & than switch to standby. Mike.
Posted on Jul 26, 2007
I read on a few other sites that you hold the vol+ & the vol- buttons down when you turn the tv on. Although this did not work for me.
Posted on Jul 10, 2007
SOURCE:
Disconnected wire in projection tv
The wire u though,cause ur problems.It nothing,probally been there all the times.It just a basic extra grounding wire came lose or ur tv got it service before,the tech.just didn't connected back in.
The problems u describing,Ur tv have Convergence Problems,it dead.U know how solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 31, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Tip
Service menu codes hitachi
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
RPTVs :
F59 SERIES
* Press and hold the {MENU} button on the TV.
* Then press the {MENU} {8} {SELECT} buttons on the remote.
* To exit, press the {MENU} button on the TV or
the {EXIT} button on the remote control.
DCAM Mode:
* Using the remote control:
* Hold down the {TV} button.
* Press the {MENU} button.
* Press the {INFO} button.
* Release the {TV} button.
* Remote Control Key Functions When In DCAM Mode:
{INPUT} ............. Blue (13x9 adjust)
{ASPECT} ............ ROM Write
{DAY/NIGHT} ......... ROM Read
{MENU} .............. Remove Color
{EXIT} .............. Cross Hatch/Video Mode
{INFO} .............. Green
{GUIDE} ............. Calculation
{2} ................. Cursor UP
{5} ................. Cursor DOWN
{6} ................. Cursor RIGHT
{4} ................. Cursor LEFT
{0} ................. RED (7x5 Adjust)
{STOP} .............. Initialize
{PLAY} .............. Raster Position
{FAST FORWARD} ...... Phase
To Exit The DCAM Mode:
* Press and hold the {TV} button.
* Press the {0} button.
* Press the {1} button.
on Apr 29, 2015 | Hitachi Televison & Video
Black box in middle of screen
Read the manual about picture in picture and turn it off. I hope this helps.
Jan 12, 2009 | Hitachi 32HDL52 32 in. LCD Television
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
37" Sceptre naga TV problem
there is a repair center in mountain view of of old middlfield its called( awake tv.)they fix lcds plasma and others even do house calls hope this helps mannyruss
Jun 15, 2008 | Sceptre Naga III X30XSV 30 in. LCD...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Green Area appears in lower part of screen
wayne, is it there as soon as the image comes up or does it have to run awhile before it appears? Let me know,
Nov 29, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Blue and red shadows on screen
This sounds like one of the convergence IC's has cracked loose or burned out, and should be replaced and realigned by someone with experience.
Jun 26, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi C21RF39 21" TV Logo
163 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
