Question about Plumbing
Gould Water pump Problem
My daughter has a Gould water pump (Jet) and recently it has been making a very strange on and off (or up and down noise) whereby the PSI Gauge goes from 0 to 40 or 50 PSI - fluxuates.
She also has a UV filtration system attached to the Pump system and we noticed a small leak (Maybe this is the problem....not sure).
Can you give me an idea what to look for or how to fix this problem without calling the Pump company.
Thank you
Art Thorburn
  • jesscajuucom May 11, 2010
    During the bad weather and we had no electricity,i suspected my 1hp goulds pump was submerge during the flood . And when there was electricity already, i waited for it to dry before turning on the switch. However, when i turned on the switch, a sound burst as if it shorted and smoke came off. Do you think the motor was damaged or is it protected by an overload switch that even if it smoked the motor will not be affected?
  • 15,935 Answers
Sounds like cavitation in the pump due to the introduction of air. Check for leaks or cracks in the suction line so air isnt being induced into the pump.
Posted on Dec 22, 2008
Water pressure gauge fall from 50 # to 20 # before the pump starts
Posted on Jul 07, 2013
My j10s can dry, can it get fixed, it was only about three months old.
Posted on Jun 24, 2012
Sounds like its water logged. No air in tank,drain water tank.
Posted on May 11, 2012
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
PRIME A GOULD PUMP
whats your question how to prime the pump? if so at the bottom is a 3/4 inch plug screwed into it, or at top, once the pump is hooked up to the lines turn off the power, and unscrew the prime plug fill with water, then screw in tight DO NOT USE THREAD SEALANT THEN THROW THE POWER TO THE PUMP, of course house supply valve must be off 3/4 turn valve off until the line is primed then open the supply line to house slowly to supply the water to all the lines, NOTE WHEN YOU FIRST INSTALL A NEW PUMP, HAS TO BE PRIMED, HAVE TO HAVE SUPPLY LINES FROM WELL TO HOUSE CLOSED TO PRESSURE THE TANK AND TO FILL THE LINES.
Apr 27, 2014 | Jet Flo 04325143A Marine Heavy Duty Water...
Gould j5s, pump not going above 15 - 20 psi, does this sound like it could be a priming issue or not since it is pumping some water?
how much pressure do you want with a 15 to 20 psi, really what are you pumping house water, you need more pressure to supply a home like a 60 psi with an exterol tank
Nov 18, 2013 | Jet Flo 04325143A Marine Heavy Duty Water...
Gould water pump not comming on
Check for power to the pump then check again after the built in pressure switch. You can get the manual from Flotec at: http://www.flotecpump.com/ResidentialResourcePage_resourcepage_ownersmanuals.aspx
If the motor buzzes then there is probably a bad start capacitor.
Sep 02, 2013 | Flotec Corrosion Resistant Shallow Well...
20+ year old Gould 1/2 hp jet pump in basement pulling my water from a deep well. It has become very loud whenever it turns on. Is there a way to lubricate it? my plumber says no...leave it alone. but...
Any pump that makes more noise that a small hum when operating is going out. Either the windings or a bearing is wearing out.
I would suggest you get it fixed by a motor shop or replaced before an emergency presents itself.
Rod
US Parts Center
888-521-6183
Feb 20, 2013 | Pool & Spa
How to prime a gould j5 well pump no plug on top
you have to have electric power to use a jet pump more info needed as to what is going on
Nov 04, 2012 | Jet Flo 04325143A Marine Heavy Duty Water...
How do i prime a gould jet pump
turn pump on,pour water in the 3/4 plug on the top of pump.feathering the valve so its not open all the way.
Apr 26, 2010 | Jet Flo 04325143A Marine Heavy Duty Water...
Water pump cli
Sounds to me like she might have spun a main bearing......
Jul 16, 2009 | 1997 Honda Civic
I have a 2004 Chevy Trailblazer LS with strange noise.....
If it is making a noise in the belt area, have them check the water pump. These get loose water pump bearings that cause belt noise.
Jun 21, 2009 | 2004 Chevrolet TrailBlazer
Clutch making strange noise when changing gears
It sounds like your clutch release bearing is worn/noisey causing fault
Feb 15, 2009 | 2002 Audi TT
Plumbing Logo
2,395 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
