Question about GE Dishwashers
It is displaying 1hr on the digital display.
There is no trobleshooting info in the manual for this problem. The dishwasher obviously has power, but when I try to turn it to any cycle it will only read 1hr on the display.
Any insights?
Thank you,
Good morning. Thank you for your support. I did in fact solve the mysterious problem. The dishwasher has a delayed 1-3 hr timer on it. Apparently some fingers decided to play with the key pad and it had to be re-scheduled.
Thank you for your time.
Posted on Dec 20, 2008
Where can I find what the codes stand for in display
probably the manual or the manufacturers website
search ..display codes <manufacturer> <model#>
Nov 15, 2016 | Dishwashers
Change from lcd moniter to view finder
Try this, in your manual at the bottom of pg. 229 that says, "If you turn off the power while the 'shooting settings display' screen is displayed, the same screen will be displayed when you turn on the power again. To avoid this, press the <INFO> button to turn off the display on the LCD monitor, then turn off the power switch."
The converse also applies. Get into the shooting settings display with the INFO button and power down. The display will come on when you power up again.
It also solved my problem of getting the mode selection button selections to show on the LCD when needed.
Jul 13, 2014 | Canon EOS 7D Digital Camera
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The dishwasher is brand new. We have connected it. However, when we switch it on no power light or any of the functions display anything There is clearly power, as the machine does go through the motions
Well by going through the motions I assume you mean it fills and washes etc. There is just no lights on the display. Since it is brand new my guess is that it is a bad display. perhaps a connector came loose during shipping. Either way you should not have to mess with it. Contact Bosch and have them take care of it. You could try and see if there are any obvious loose wires. Turn the breaker off at the panel so there is not power to the unit at all. Then look around for a loose plug module something like these
Jun 03, 2011 | Bosch Dishwashers
My flash will just not turn on. I have a casio exilim EX-Z35
At back camera, have lamp flashes orange where to indicate flash is charging and to tell image will not recorded(disable). You will can not take another flash until that lamp is stop flashing orange to indicate charging is full. in other view, please check at lcd screen have appear flash icon.
click button play mode to display menu. change set flash to on if flash icon is not display
for user manual
User manual trobleshoot
May 09, 2011 | Cameras
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
GE GSD 4920 digital display not lighting up, but the machine is running. How do I fix this? Ilana
If its actually running through the cycle normally, with all functions as they should then the power board is ok, BUT the display board part # WD21X780 - SIG BRD&HSG**NLA 01/08** is showing as no longer available unfortunately.. if you can find it expect to pay a fair chunk of change for it..
However if you tear the door and console apart you may inspect the display control board and find a very obvious broken wire to the display.. ya just never know.
best of luck, and have fun,
Feb 01, 2010 | GE GSD3800G - Multiple Color Built-in...
Display clock on our Sony Bravia LCD Digital TV KDL-40V4000
Keep pressing the info button on your remote to cycle through the three? options. One or two presses will make the digital clock display again.
Jan 18, 2010 | Sony Televison & Video
Can only record in black & white?
try changing your Display/ TV Connection setting under the setting menu - it may need to be set to "composite" (not RGB) if connected as displayed in the instruction manual - worked for me anyway (hope it does you).
Jan 21, 2008 | Archos 605 WiFi Digital Media Player
Dishwashers Logo
338 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
