Hi, I have a Lumix DMC-FX01 and the lens seems stuck in the retraction mode. You turn the camera on and after a couple of seconds it tells you to turn it off and on again. As if it is stuck in battery saving mode. The lens does not pop out at all. Everything else seems to work fine, and I reset it, hoping that would solve the problem. I have tried tugging the lens out, and tapping the camera, but only very gently. Any ideas anyone?
thanks,
erik
1 Other User Has The Same Problem
Comment by shedawhiting, posted on Nov 07, 2007
Hi, I have a Lumix DMC-FX01 and the lens seems stuck in the retraction mode. I turn the camera on and after a couple of seconds it tells you to turn it off and on again. As if it is stuck in battery saving mode. The lens does not pop out at all. Everything else seems to work fine, and I reset it, hoping that would solve the problem. . Any ideas anyone?
To help you get it apart, take off all the obvious outside screws and then unhinge the back and front, with the hinge point being the top.
The back and screen can easily be removed by tugging on the cables where they fix into the circuit board. (Just push the large cable back in, for the smaller cable you need to use the little hinge on it (initially put the hinge towards the edge of the camera, insert the small cable, then fold the hinge back towards the centre of the camera.
Continue to take out small silver coloured screws with a jeweler's screwdriver. I was able to get to the elecromechanical optical train in this way. I did not have to remove the tiny black screws inside this unit. After thorough cleaning and blowing out dust/ sand etc. the camera was fairly easy to put back together.
Total time was about 90 minutes.
Note: there was no need to take off any of the buttons on the top, nor to take out the battery nor memory card.
Good luck.
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Panasonic Lumix DMC-FX01 Digital
Email this problem
Can you Help with these Digital Cameras problems?
panasonic lumix dmc-fx01
My Lumix DMC-FX8 shows
Problems with my Lumix
Weird lines / purple craziness...
Video not recording on fastcard
