Question about LG MZ-42PZ44 42 in. EDTV-Ready Plasma Television
Diagonal dark lines cross screen
Hi all when i switch the tv on i get dark diagonal lins that move up and down the screen . thay also go thick then thin it then diagonal both ways . thay go arfter its warmed up aroun 10 minets the model number is mz-42pz44 with the tv tuner si screwed ot the back and the model number is rt-ba50 make is lg. thanks to any one that halps
    Top Expert:
  • LG Master
  • 75,169 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Nov 14, 2017
5 Suggested Answers
likha
  • 790 Answers
SOURCE: LG MZ-42PZ44 42 in
you have fault oscillation! u have defective parts
Posted on Sep 12, 2007
s4u311
  • 813 Answers
hi friend
u need a user manual see the in menual tell me whats ur tv model no
Posted on Apr 12, 2008
  • 12 Answers
SOURCE: LG MZ-42PZ44 42 green LED stays on
Have a look at my 'I broke the glass post'
Posted on Jun 06, 2008
  • 12 Answers
SOURCE: LG MZ-42PZ44 42 in. EDTV-Ready... Problem:
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Dark cloud thick lines appearing on my LCD TV
It sounds like a loose contact to your T-con panel. Before the problem happened, had you recently moved your TV? A picture would help my friend also if you have the model number.
Jun 17, 2013 | Televison & Video
Problem with my Magnavox DVD player, DP100MW8, picture dark and lines across the screen
Hi, if the lines are diagonal sounds like it is set to progressive scan mode-which means if there is not a switch on back saying P/S and interlaced then you need to connect to T.V. with component video inputs ( indicated by red,green,and blue colored R.C.A. plug inputs) and Pan and Scan capable-then in menu setting select interlaced picture output. hope this was of use, good luck prodzilla
Mar 30, 2011 | Televison & Video
Hi i have a lg 50pg3000 plasma the screen has 2 thick black lines down the righthand side thay some time go bum most of the time stay unless i give the tv a bit of a twist then the lines go for about 1hr
Hi, you can try tightening the ribbon cables that run from the screen to the buffer board , only tighten the one near the line area. if this does not help you probably need a new buffer board or panel (screen)
Feb 17, 2011 | LG 50PG20 50 in. Plasma HDTV
Dark horizontal line scrolling up from bottom of screen
if you are using a cable box .. then disconnect everything that is feeding signals into the tv ... then get a signal from some other source (like off the air antenna or video camera) ... if the tv still has the dark lines then you have a bad primary filter capacitor in its power supply .. if it works ok off the air and only does it when the cable box is hooked up .. then the cable box has an open primary filter capacitor . ... the dark horizontal bars you see is ripple from the rectified AC power that is not properly filtered ... if the TVs verticle scan rate is 60 hz and the full wave rectified AC amounts to 120 hz ripple then you will see two dark bars across the picture ... since the two signals are not syncronized then they will slip in phase with respect to each other .. thus the constantly moving pattern ..
Apr 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Diagonal green lines on a green screen
It is possible that the electron-gun inside of the CRT is having an intermittant short. It is also possible that there is an intermitttant failure in the bias or drive circuits for the CRT electron-gun.
The TV service tech would have to run some tests to determine the actual fault, and then the failed components.
If the CRT is at fault, the set will not be worth to service.
Jerry G.
Apr 25, 2008 | Televison & Video
Lines on screen
Can you take a picture of the screen and post it? It is not possible for both the horizontal and vertical stages to fail at the same time to produce a cross. A picture of the screen would help significantly.
Aug 08, 2007 | Daewoo DTQ-25S2FC 25" TV
Diagonal lines
Hi It's difficult to be sure without being able to see the lines myself, but what it sounds like is some stray RF is getting into your video signal. Although your cables are supposed to be shielded, this is a common problem. The first thing I would do is move the cables or cable you are using, in relation to any power cords hanging down behind your equipment while someone watches for the lines to change or dissapear, and is that has no effect, then if possible change the position of the VCR in relation to the tv, so that if for example it is under the tv, move it to the side, or farther away, and the lines may very well dissapear. That problem is due to a common interaction between the tv and vcr where there is not enough shielding, usually inside the bottom of the tv set. Hope this helps, good luck!
Feb 11, 2007 | RCA VR546 S-VHS VCR
LG MZ-42PZ44 42 in. EDTV-Ready Plasma Television Logo
65 people viewed this question
Computer Repairing
Computer Repairing
