The maximum speed of a 1962 Dodge D-400 6-cylinder 125 hp vehicleis about 106 mph.
Sometimes The maximum speed of a 1962 rambler American 440 automatic 6cyl 125HP is/was 95mph or 152.88kph.
1963 rambler Laticia, Sound like your Rambler Flash O Matic transmission needs internal work/rebuilding. Have checked by a good tranny shop. No drive gears could be clutches, valve body, pump,bands,etc. Check the attached links, transmission kits and replacements. Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
what I did was removed the 287 engine installed an AMC 360 .In order to do this you have to get an borg warner m11 bell housing from 67 to 71 .amc used borg warner transmissions until than. So you put the m11 bell housing on to the m8 transmission and get the motor mount for the AMC 360 engine
Mark the position of the distributor. Remove cap. Loosen the distributor hold down bolt.and turn distributor to raise the points cam follower to one of the lobes on the cam. Remove the screw that holds the points assembly. Remove points with the capacitor attached. Put you new points in the same position as the ones that you removed. Points should have .030" gap. Tighten points- hold-down screw. Turn the distributor to the original (marked) position. Tighten distributor hold-down bolt. You should now be able to start, but you may need to set the timing.
ramblers were a mixture of the" big three" back in the '60s you might see if a steering box from a dodge ram series pickups or ford f series pickups may fit. also,check closely on the steering box for a casting number,parts suppliers use these numbers as a cross reference to match other steering boxes to your application.
