Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Top rack keeps slipping off of tub rollers.
My top rack keeps coming off of the left rear tub rollers. I have replaced both left rear tub rollers and tub roller screws. Has anyone else seen this problem?
  • lisste Mar 05, 2008
    yep - the top left side of the rack came off the rollers. This happened about a year ago, but some one was over that knew just what to do and fixed it. But it's happened again
  • robfam Feb 15, 2009
    dose any one have part numbers for the better rollers
I was sold this model and had the same thing happen.. However when calling for service, my service rep would not come out, so I contacted Fridgidaire and provided the model and serial # of my unit and was told I was sold an unrepairable unit that had already been returned for service for the same thing and considered unrepairable and was no longer under warranty. When my supplier finally came out he put new longer rollers in my dishwasher, but when I mentioned what Fridgidaire had told me, he went back to his supplier and they got me a new one. Being installed today.. The new one is a PDA2855 model as I am told that the PLD2850 is no longer sold.
Posted on Sep 06, 2007
Kenmore top load washer,model 110 20102311,should i be able to move tub from top very easily in any direction or should there be some tension,my tub is banging of side walls in spin cycle
The tub should move easily from side to side, however, a better test is to push down sharply on the tub and let go, it should come up and stop the first time, not bounce up and down several times. If it bounces up and down the suspension rods are shot. The part number for the kit of 4 is W10780045, all 4 need to be replaced as a set. To replace them the top needs to be loosened and lifted up, the rods disconnected from the top 2 at a time and replaced (doing opposite corners makes it easier IE: front right and left rear, front left and then right rear). Disconnect the top ends of two rods, lower top, lean washer back and pull out the disconnected two rods from the bottom, reverse the process to install.
Sep 30, 2017 | Kenmore Washing Machines
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
How do I get the upper rack arm back on the rollers?
The back endcap on the slider has snaplocks that has to be squeezed then pull off. This should allow you to pull the slider out and then guild it back over the rollers and into its proper place. Just had to do this, and it's hard to get to with the door down, but can be done.
Jan 13, 2015 | Dishwashers
The top rack - missing pin
At an appliance spare parts shop or by calling a number in the booklet that came with your dishwasher that you probably don't have anymore.
Jun 03, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Water not getting to upper wash arm / glasses on top rack are dirty after the cycle - I do not know how to take out top slide basket to check water flow in tube at rear of machine-
remove the roller rack plastic end caps this will let you remove the upper rack,then you can replace the whole wash conduit from the bottom sump all the way to the top,also if theres a middle(center arm) this has a horn on it that is to seal when the rack and door are in and closed,but after while the water wears out the plastic o-ring and they leak and you lose water pressure to the top wash arm
Apr 01, 2010 | Dishwashers
I can't put back the top dishwasher rack. The railing does not seem to hold it, even though there is no damage in the railing. The top rack could not be held by the rollers
There should be plastic stops at either end of the rail that prevent the rollers of the rack from coming out of either end.
Sep 22, 2009 | Maytag Dishwashers
Noise from top rack
THEN RUN THE RACKS AT REAR WHEN THERE IS NOTHING LOADED. THIS NOISE IS BUILT IN BY THE DESIGN, THERE IS NO "FIX"
Aug 27, 2009 | 2006 Toyota RAV4
LG DIshwasher
hi Problems with the dish racks usually occur because the racks have been jammed back into the tub housing after they're fully loaded. Careless handling can exert enough force to crack or break the roller wheels or throw the racks off the tracks. The solution is easy: Stop jamming the racks.
The repair is easy, too. Remove the racks by pulling out the tiny metal pins that hold them in the tracks. Or simply lift up on the racks and pull them out of the tracks. Then reinstall the racks on the tracks so that they roll smoothly. If the rollers are cracked or broken, replace them with new ones of the same type. The rollers may be friction-fit to their hubs. Pull them off for replacement. Or, if they are held by tiny spring clips, pull the clips out with pliers, or pry them out with the tip of a screwdriver. If you can't pull the rollers off for replacement, remove and replace the entire rack.
Sep 12, 2008 | LG Dishwashers
Only some cups on top rack are getting cleaned
It sounds as if you have some rollers missing on the bottom rack which lets the rack sit on the sprayer therefore not letting it spin. You should have 4 rollers on front and 2 on back of rack. If you are missing two on one side, take one from the other side until you can get some more. Just make sure you have a roller on all four sides of the rack
Jul 18, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Does not clean dishes on top rack
DG:
There is a rubber boot connecter in the back of the top rack which slips over a pipe coming up the back of the unit. This is how the water gets to the top rack. That boot is subject to rot and breaking. Check and see. It should be easy to replace, if you can get the part.
May 11, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
167 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
