Question about Dell W4201C 42 in. Plasma HDTV
Black screen on 42inch dell lcd tv
My tv has a black screen but the sound works
  • Anonymous Mar 13, 2009
    My Dell 4201C 42" Plasma TV, which developed a black line down the screen vertically.
  • kenn green May 11, 2010
    are you able to use any of the inputs?
    New Friend:
  • 90 Answers
Your Y-main bd buffer(s) upper and lower. needs replaced. to do this, u need to remove the back cover with a t20 torx bit + phillips screwdriver. once removed, look to the far left, there are 5 or 6 long snap on connections they run along your Y upper and lower buffers. look at them carefully for burn marks around the sealants. if u notice a orange burnt residue, its prob burnt out and needs to be replaced. this should enable the video once again.
Posted on Mar 02, 2009
Easy touch 42inch lcd tv black screen
replace power supply and mainboard
Jan 21, 2013 | Televison & Video
My 42inch vizio flat screen tv has no sound. Great picture
check the sound set up menu first if set to off. if ok check the speaker weather is worn out.
Sep 20, 2012 | Vizio E421VO - 42in Lcd 1080p 60hz Hdtv
47" plasma 1080p ... screen went black , sound
Plasma TV's have a shelf life. By that I mean the screen is only good for so many hours depending on the model. Most likely, you have burnt out the screen and the set will need to be replaced. The good news is, plasma TV's used to be better than LCD but that is no longer the case. You can get a very high quality LCD TV for a very low price now. Also they use a fraction of the power and don't generate all of the heat of a plasma.I'm sure this is not what you wanted to hear but the reality is that ALL plasma TV's do this eventually, and it is something that most salesmen back in the day didn't bother to tell customers. If you have an extended warranty, you may be able to get it replaced.
May 05, 2011 | H&B HP5500V Plasma TV
My sylvania LC427SSX 42inch lcd. i turned it off and when i turned it on in the morning the screen is black, i can hear sound and if i hold a light up to the screen i can see an image
It seems back light inverter is not working for some reason, either it is not getting volts from power supply board or got bad itself.
Please check with local tv repair shop for replacement back light inverter board.
Thanks.
Mar 16, 2011 | Televison & Video
Philips 42inch LCD flat screen tv
It could be a Power supply problem or a Main Board problem. Best to have a Pro look at it for you.
Jul 13, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Invalid format
my xbox 360 when hooked up to my 42inch Lc7d get sound but displays invalid format error,  how can this be fixed?
Jul 07, 2008 | LG 42LC2D 42 in. LCD HDTV
42inch dell plasma
The black bars are a common problem with these dells. My understanding is the warranty is good for two years. Be persistant with them.
Jan 24, 2008 | Televison & Video
DELL 42 inch Plasma TV
I have a 42" LG LCD TV and just experienced this today. Watching cable, then the screen went to black, but audio continued. I pressed the guide button on my remote and pic came on with my guide menu. But then went to black again 10sec later and has remained that way for nearly an hour. Tried switching off both cable box and TV, disconnecting and reconnecting cables, but no luck. Finally unplugged mains, waited a minute, then turned back on. Everything seems normal now after the reboot. Phew.
Jan 17, 2008 | Sony KV-36XBR450 36" TV
Hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
Dec 23, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Dell W4201C 42 in. Plasma HDTV Logo
331 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
