Question about Mitsubishi VS-55707 TV
Mitsubishi CRT Is Mitsubishi doing anything about the leaky crt problem? Are all rear projection tv's having this problem? Can you tighten the seal screw to prevent leaking?
  • Mitsubishi Master
  • 5,138 Answers
No, Yes mostly RCA,Yes ,must redo lense covers
Posted on Dec 19, 2008
I have a Mitsubishi WS-65807 Projection Tv and while I was watching a program the picture went to a black screen. The audio works fine and when I go to the Menu it shows up fine. Any input as to the...
Thats usually a vertical issue since the menu still works. I would check the solder on the vertical IC and also the Vertical yoke plug pins. Often solder can develop a small crack around the pins and resoldering will usually fix the issue in most cases. The other item could be a leaky CRT has dripped some coolant on some of the components in the vertical circuit so I always check the board for any sign of a clear sticky residule on the boards which indicate dripping CRT coolant.
Jun 07, 2011 | Mitsubishi WS-65807 65" Rear Projection...
VZ5 Chassis mitsubishi VS-60603 With excessive brightness
If experiencing excessive brightness in the VZ5 chassis mitsubishi's it usually can be traced back to a leaky transistor on one of the CRT PC boards. Check Q6R1 on Red PCB, Q6B1on the Blue PCB and Q6G1 on the Green PCB one of these transistors will most likely be leaky
on Feb 23, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Apr 24, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mod#vs60607 tv
Check for wet area on signal PC board = leaky CRT seal.
Apr 15, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Color problem with tv
Sounds like you may need a blue CRT. Can you look in the rear of the set and tell if the blue CRT is lit up?
Apr 14, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi 55 rear projection
sounds like yor green crt is shorted or you have some bad solder connections on the green CRT socket. Check the board with the green CRT socket for cracked solder. if the soler looks good your CRT is probably shorted.
Feb 02, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Practice visual acuity technique!Examine signal pcb for evidence of CRT coolant leak.Usually circuit board can be cleaned,then replace leaky CRT--at least one w/bad seal.
Sep 28, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Screen has a Green Haze to it........
Apr 20, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-55707 TV Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
