Question about Apple Power Mac G5 Desktop
Power PC G5 Dual 2.5 sudden shutdown and no reboot
Recently I replaced the power supply (blown) from my G5, after that is shows an unpredictable behavior. It is running great for a week, all of a sudden it shutdown the video, ramp up the fans, front white led on. When you reboot, front led light up but turns off quickly, fans start, gongs but suddenly you can see front led turn back on and simultaneously a red led deep inside the machine (not the leds close to RAM) and video never begins and stays there until fans ramp up after a couple of minutes. All leds close to RAM off.
Ran Apple Diag disk and passed all, but when you try a thermal calibration it says either radiator pump error, or to remove/replace clear plastic door.
What could it be?
  • 1 more comment
  • localhost Feb 14, 2009
    It is not the airflow cover unseat light, which is by the RAM. and the 2.5 GHz does not have the 7 diagnostic LED's, that's only the last generation of G5's. I have the same problem as OP, any clue what these red LEDs deep in th machine might indicate?
  • Sean Cole
    Sean Cole May 11, 2010
    Did u manage to fix this problem?
  • Sean Cole
    Hi Marcos845,
    Sorry to hear you're having problems with your G5. If you open the side panel (but not the deflector shield) there are 7 LEDs next to the RAM ports - 6 directly to the left and 1 just slightly below and to the right of the others. Let me know which ones are lit numbering them from top to bottom.
    All the best
    Sean
    PiDigital
    Sergeant:
  • 369 Answers
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Posted on Jan 04, 2009
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
I have a 17" imac g5 that will no power up. no
Check for blown capacitors on the logic board and power supply. If you have signs of blown capacitors you will have to replace logic board or power supply.
The trick is getting the computer open. Stick a credit card in the back vent at the top of the display. Their are two tabs one and each side of the vent push forward unscrew the screws at the bottom. sit it up facing you and pull the top to you. be careful of the isight cable at the top. you will need to unscrew the LDC from the housing be careful of connected cables and check under for the blown caps.
Jan 24, 2011 | Apple iMac G5 Desktop
I havd a Dell Dimension 8200 that sometimes shuts down and power light turns yellow. I can usally open case and plug and on plug to get it to power back up. Recently replaced fans due to fan failure....
Thank for the detail, it really helps...
Most people forget about the power supply. If the power supply overheats, it will shutdown. When shutdown, it will cool off then operate again.
A power supply goes by WATT ratings, the average size power supply is now 450 watts for an average system and should cost around $60.
good luck and don't forget to vote.
Oct 12, 2010 | Dell Dimension 8200 PC Desktop
My desktop shutdown after several minutes, reboot it again but it shutdown again. reboot again but same thing happen, pc shutdown. what is the problem?
That's like stating my car was going down the road, then suddenly died. What is the problem?
Open the hood, take a look. Maybe it's something obvious.
Same thing with a computer.
1) Computer unplugged from power, open the computer case. See if the Processor fan is dirty, and the computer case fan/s.
If so use a can of compressed air for computers, and clean.
[NOTE*
BEFORE you reach inside your unplugged from power computer, observe Anti-Static Precautions ]
2) See if there are Electrolytic Capacitors on the motherboard.
Bad capacitors for the motherboard voltage regulator circuit, will cause rebooting.
How to identify bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
The motherboard Voltage Regulator Circuit,
http://www.hardwaresecrets.com/article/616
Example;
http://www.youtube.com/watch?v=KN6_-8fYHo0
(Starts at 0:04)
3) Power Supply
Weak Voltage power rail. Caused by failing Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitors)
Sep 04, 2010 | MSI Computers & Internet
Sleeps and won't wake up. unblug pwr supply won't shut down properly. when pwr supply is plugged back in, monitor like comes on blue then amber like in sleep mode. Nothing shows on monitor. ctrl /alt/del...
Hello
Thank you for using FixYa for your problem
Needs a techie toolkit disc to run HDD regeneration scan then try the repair mode in your install disc, (2nd repair mode)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Gateway GT5625E Refurbished Intel Desktop...
Plugged in not charing, power available 92%
Shutdown PC. Then remove battery and Plug in AC power cable. Boot Computer. If everything fine, then shutdown again>put battery back and try! It should work. I had similar problem.
Jun 18, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Power Supply blew up, need to replace
Hi, Sorry to hear you are having problems,
Here is a very useful website:
http://g5.bhmm.net/
it will show you how to take apart a Powermac G5 step by step.
Mar 16, 2009 | Apple PowerMac G5 Dual Mac Desktop
Suddenly pc restarted.
Your CPU is overheating
1) Turn off computer and remove case side
2) remove fan from "heatsink" do NOT remove Heatsink "Usually this is stuck with solidified heat paste"
3) clean all dust and dirt from heatsink and fan.
4) vacuum out case Include behind power supply and video card.and any other fans
5) use stiff brush and vacuum outside of power supply
Reboot and see if still restarts if not everything OK
shutdown PC and refit case side.
This is a common problem on a lot of computers as the environment they are used in is usually dusty.
I do mine every 3/4 months and have no problems like this
Please when works give me a fixya
Jan 27, 2009 | Biostar P4M80-M4 Motherboard
Mac G5 shutdown and now won't power up
Sounds like a bad power supply. They do go bad... get a new one and hook it up without installing it. If it boots your machine...you've solved your problem. That battery retains some boot info and your date/time settings.
Jan 02, 2009 | Apple Power Mac G5 Desktop
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Apple Power Mac G5 Desktop Logo
538 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
