Question about SanDisk Sansa E280 MP3 Player
Frozen after removing from my computer the player is frozen on
  • 8,596 Answers
Download the Sansa Recovery Tool from Sandisk's website (make sure the Sansa is not plugged into the computer yet). Once the Recovery Tool is downloaded, connect the Sansa to the computer while holding in the REC button and continue to hold it even after th player is plugged in. It should go into Recovery Mode in 10-15 seconds or so.
-Tha Mp3 Doctor
Posted on Jan 18, 2009
My player turns on and displays the pearl icon and no longer moves
Hi
Try removing the device's battery.
Leave the player in the frozen state until the battery dies.
Connect the mp3 to a computer and turn the computer on.
Leave it charging for 15minutes an then try playing music while its still charging.
Feb 28, 2012 | Audio Players & Recorders
Says Do not disconnect on screen and is frozen there
If the Player is frozen while connected to the Computer, then reset the Player by pressing the RESET button without disconnecting from the Computer. Once the Walkman player is reset, then remove it from the Computer. If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object.
Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed.
After charging the Walkman Player, you can use it. If the issue persists, FORMAT the Player to resolve the issue.
To format the player, select the FORMAT option from the Common Settings menu of the Player.
Thanks for contacting FixYa.
May 07, 2011 | Sony NWZ-E436F MP3 Player
Frozen
update its drivers from your computer then remove battery and restart.
Jan 22, 2010 | Philips GOGEAR SA6045 MP3 Player
My zen is frozen on creative
If a reset does not work then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Feb 20, 2009 | Creative Labs ZEN V Plus MP3 Player
I tried to remove a song, and now it is frozen.
if your ipod is frozen, hold down the center button and the menue button at the same ezact time. this should refresh your iPod
Feb 06, 2009 | Creative Labs Zen Touch MP3 Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Player frozen
You should let the battery be flat and then charge it.
It'd then work. It happened to me twice. Hope this helps.
Dec 05, 2007 | Samsung YP-T7Z MP3 Player
Need help
Oct 07, 2007 | SanDisk Sansa m240 MP3 Player
C150 frozen!
Try a hard reset press and hold vol + and center select button for 20 seconds. Best of Luck.
Oct 01, 2007 | SanDisk Sansa c150 MP3 Player
Frozen Screen
You should try formating the drive. With the drive plugged into your computer, go to "My Computer->Right Click on the Removable Drive representing the MP3 player->Select Format"
Jun 22, 2007 | RCA eMusic MP3 Player
SanDisk Sansa E280 MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
