Panasonic Workio DP-1820E Copier
Problem for Panasonic Workio DP-1820E Copier
Black streaks (in direction of paper travel)...
By rhearnacs on Dec 19, 2008
Black streaks (in direction of paper travel)... They come & go and vary in length and thickness. One or two always seem to show up in the same place though. Looks like what I've seen on other machines that use organic drums and have dirty charge wires or a malfunctioning grid/scorotron. I've cleaned and then replaced the corona unit in the past but black streaks still come back in the short term. I also cleaned the contacts on the back end of the drum modual. Oh! This is not a fuser roller issue.
Comments:
Dec 22, 2008
- Nope! That's Not It!!! Thanks a whole bunch though swan34. I replaced it two times already and no change. I'm sorry I didn't think to mention that in my 1st post but, this issue has me soo upset I can't think straight some times... What To Do??... What To Do??? Sniff...
I did have a bit of a brainstorm this morning... I went 'oldschool' on the thing (guess that means I engaged my brain) and started pondering "corona current"/"grid voltage" control... Maybe charge is just too low! Any body got a clue re adjustability. Back in my day (I got started when machines still used coated paper...) corona wire position and/or charge current was adjustable. Of course in those pre-laser exposure systems, low charge rendered as white streaks where in these laser driven puppies low charge looks like black streaks, yes? I'm gonna go try and find a svc mnl for this beast.
Thanks Again swan34 !!!
RAy
Best Solution
posted on Dec 20, 2008
Helpful)
swan34
Rank: Wiz
Rating: 83%, 449 votes
Dear sir; As your description, seem you have drum cleaning blade problem ,why don't give a try to replace it,let me know if you need more help. good luck.
HAVE A HAPPY HOLIDAY !!!
Was this helpful?
Yes
No
Solution #2
posted on Oct 14, 2009
Not Rated)
Guru Guy
Rank: Guru
Rating: 87%, 46 votes
This model is NOTORIOUS for not being able to handle the amount of toner in the cleaning unit due to it's location (over the drum...wtf!). When you start seeing those lines...not real sharp but rather a "burn" looking line...it's usually time to pull the drum out and clean out the cleaner unit. Make sure the mylar strip under the cleaning blade is not folded or bent back. Just run your finger over the mylar strip several times at the base where it is mounted, and the heat from the friction will tend to straighten it back out again!
Was this helpful?
Yes
No
Popular Solutions for Panasonic Workio DP-1820E
Questions and Unsolved Problems for Panasonic Workio DP-1820E
Do you recommend Panasonic Workio DP-1820E Copier?
Answer
Answer
my mita dc 1260 copier has failed to get into simulation mode
Answer
where can I get a scanner chip for a panasonic workio 1820
Answer
I have a faded vertical section when I print on my Workio DP1810 Copier. I have changed the toner so... (More)
Answer
i have a canon pixma 830 it showing a error code a600 anyone can help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Workio DP-1820E...:
Top Copier Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
