Question about Toshiba Satellite A105-S4004 Notebook
Laptop CD/DVD Drive
In trying to copy files from my laptop, I put in a brand new CD and an error message comes up" The disk you were saving to or the disk used for temporary files is full. Free some space on this disk & try again or save to a different disk". I try another brand new RW disk and the same message appears.
  • ernie siegrist Mar 31, 2007
    I'm not sure what you are refrring to. My op system is Windows XP.
  • 624 Answers
In order to copy files to a CD like a hard drive you need a program that can treat the CD like a hard drive. Sometimes called *drag and drop or drag to disk*, is this what you?re using and if so what program are you using?
Posted on Mar 31, 2007
  • tomj23 Mar 31, 2007
    Windows by itself can't write to a blank CD. If you bought your laptop with a CD writer drive it came pre-loaded with a program, probably Nero or Roxio that actually writes the data to your CD drive. Both of these programs also have a component that allows you to prepare the blank disk so that you can just copy files to the CD just like a hard drive or floppy disk (drag to disk). The down side of *drag to disk* is that the disk can?t be read by very many other drives.
    Let us know what program you have, also are you trying to back up data to the CD or are you trying to share files?
Toshiba disk drive mk6028gal
The hard disk drive (HDD) in your Toshiba laptop is the component that holds all the files and folders you use.
If you are running out of room on the hard disk drive because of all the programs you have installed, it may be time to replace it with a new one that has a larger capacity.
Replacing the hard disk drive on a Toshiba laptop is a fairly straightforward and simple process, as you only need to remove one other component to be able to reach the hard drive.
Save a backup copy of any file or program that you will need from the original hard disk drive to an external device such as a CD-RW or USB flash drive.
Shut down the Toshiba laptop's operating system completely.
Disconnect the power cable if it was plugged in and then close the top screen lid.
Flip the entire unit over so that the bottom end of the laptop case is facing towards you.
Hold down the release latch for the Toshiba laptop's battery.
Slide the laptop battery out of the case and then put it aside.
Locate the screw at the upper-left corner of the case that holds the CD or DVD drive into place.
Remove the screw and set it aside. Grab the edge of the CD or DVD drive and then pull it away from the Toshiba laptop case. Set the drive aside.
Remove the four screws holding the large square plastic cover over the hard disk drive at the lower left end of the laptop case.
Lift the square plastic cover off the laptop case and set it aside so that you can see the metal plate that covers the hard disk drive.
Take out the screws holding the metal plate in place.
Lift the metal plate out of the case and set it aside.
Remove the two screws at the top edge of the hard disk drive and then the two screws at the bottom edge of the hard disk drive.
Disconnect the hard drive from the motherboard by sliding it out towards you.
Lift the hard disk drive out of the case and set it aside.
Push the new hard drive into the open slot and then reconnect the four screws.
Set the metal plate back on top of the new hard disk drive and then attach its screws.
Put the plastic cover on and reattach the cover's screws.
Slide the CD or DVD drive back into its port and then reconnect the screw.
Put the battery back into the Toshiba laptop.
Turn the laptop over and open up the screen.
Power the computer on. Insert the recovery disk that came with the Toshiba laptop into the CD or DVD drive.
Follow the operating system installation instructions that will appear on the screen.
Transfer the backup copies of the files you saved earlier from the external device to the new hard drive.
Toshiba Satellite hard drive replacement
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Aug 13, 2013 | Computers & Internet
When trying to restore my u series 9, (ST3160022ACE) ultra ATA 160 gig hard drive I get this message: Restore was not successful. Remove any USB or Extra Hard drives taht are connected. I have no USB or...
If by "restore" you mean that you are reinstalling Windows onto the disk-drive, to restore Windows to the "as-shipped-from-the-factory" condition, then a failure of that operation can be caused by either of three conditions:
* I/O errors reading files from the CD/DVD disks (due to dust/fingerprints on the bottom of the disks),
* I/O errors writing files to the disk-drive,
* an intermittent problem with the computer's motherboard or RAM, causing "random" failures when using the computer.
So, on another computer, take the CD/DVD disks, and try to copy the entire contents (namely up to 4.7 GB) onto the 'C:' drive, watching for any "I/O errors" during the file-copy operation.
If the file-copy completes successfully, then the copy of the files can be deleted.
If no errors occur, then it's time to suspect that the disk-drive itself is failing.
Buy a new disk-drive, and disconnect the old disk-drive, and connect the new disk-drive,
and restart the "restore" operation. If the "restore" fails on the new disk-drive,
then it's time to suspect that the motherboard has a problem.
Nov 03, 2010 | Seagate Computers & Internet
Installing Vista on new hard drive- CD/DVD Driver not found
Are you installing from the SONY-supplied "System Restore" CD/DVD disks, or from a "generic" Vista DVD-ROM?
The SONY disks _should_ have the correct drivers for your notebook computer.
Dec 08, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
The InterVideo WinDVD 5 program on my laptop not working!
Maybe your CD/DVD drive is a old drive :O( , for the new cd´s/DVD´s on the marked today actually many times you need a new drive for read them. Try first if you can install with the dll found on the link below.
You can find "wnaspi32.dll'' here : http://www.dll-files.com/dllindex/dll-files.shtml?wnaspi32
Ohter solutions:
1: get a external drive(not to old) and try install it with that
2: copy the cd to a usb storage on a computer thats have a new cd/dvd drive, use the usb storage to install it on your computer, use the dll file from the link.
Hope this can resolve the problem.
Aug 23, 2009 | Intervideo Computers & Internet
System file corrupt and CD Drive doesn't work to run Install CD
First: Boot into safe mode on "bad" laptop...
Open a command window...
(start, run, "cmd.exe", <enter>)
At the command prompt, type:
"CHKDSK /F"
It will probably say something about cannot lock the volume, do you want me to schedule a disk check at next startup? Say yes and reboot...
2nd:
Does the other laptop work, and does it have a functioning CD drive?
Yes?
Copy the I386 directory of the XP install CD to the USB Hard Drive using the working laptop.
Then, boot "bad" laptop into safe mode.
Plug USB HDD into "bad lapttop", hope it is recognized and copy the I386 directory to the c:\ drive.
After the copy is complete, run
C:\i386\WINNT32.EXE
Choose upgrade if you wish, but I'd have the program replace the existing windows installation. Leave the HDD as is if asked, do NOT format it. This way, you can navigate around and find your "old" data on the HDD after Windows has finished installing.
Have your installation Key/Serial No. at the ready.
Mar 09, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Cant' figure how to hook to internet connection
It seems you have several questions. Some programs must be installed from a cd some don't.
1. You can try copying the contents of cd and pasting it to the flash drive then to the laptop into a single folder and run the install/setup program from there. This may or may not work.
2. You can install Magic Disc to your computer and the laptop.
With this program you can copy a cd or dvd into one file.
Then this program can take the file and load it as a cd rom drive.
You can download the program from this link.
http://www.magiciso.com/tutorials/miso-magicdisc-overview.htm
Once you have the program installed you should see you have a new dvd-drive in my computer and a new icon on the taskbar. The icon will have a hand holding a cd disk.
Right Click on it and select make cd/dvd image.
Select the drive where you have the cad cd.
Select where you want it saved on your computer. Make sure you click on the folder type a filename and click save or it will put the file in some strange place, and make sure you take down where it saved it to.
Keep the .uif format don't change it.
No need to make a password.
Click OK
Let it do it's thing.
When it's done you will have the .uif file on your hard drive you can run as if it is a cd drive without a cd drive.
To do this right click on the magic disk icon in the taskbar and select "Virtual CD/DVD-ROM", select No Media, select mount.
In the "Mount CD/DVD" window select the .uif image file you created.
The cd file should load just as if you had inserted a cd into a real cd drive.
To do this on the laptop first copy the installation file for magic disc to the laptop then intall it. Then copy the .uif file to the laptop and mount it the same way I said on xp.
I've use this program a ton and it works great. My kids can't ruin cd's this way. :)
Note: If your flash drive isn't big enough you can use a program like winrar or file dicer to break the .uif file into smaller pieces and move it over piece by piece.
Sep 10, 2008 | Dell Latitude D600 Notebook
Cannot copy files to DVD disks
First of all you should have the recording tab ON. Have you tried burning using Nero instead of dragging and dropping? This may solve the problem.
However, if you prefer to drag and drop, try setting the write speed to a slower setting, even if the dvd burner has faster write capabilities.
1. I do not think it is a hardware issue.
2. You can try replacing the IDE cable, but if you can read the contents of the disk it does not suggest a communication issue between the drive and mobo.
3. I do not think that the burning software is to blame, when you drag and drop you are actually using a windows based burning software that is installed with the operating system.
4. set up your files to burn through nero, let the software do the work.
I had the same issue with my dvd burner, although slightly different error messages, solved it by using nero instead.
Apr 12, 2008 | E-Machines eMachines Desktop PC
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
Dec 21, 2007 | Gateway GT4022 PC Desktop
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
