Question about GE 27938GE1 Cordless Phone (01-27938ge1)
Dial tone but doesn't ring out
Dial tone on but when dialed out only dial tone comes back on ,no ringing in effect.
  • 150 Answers
Good day Mickey, First I'll provide you with a link to the manual if you need it: I know it's a weird lokking link, it's a server from thompson which is the parent company for GE home electronics, not exactly yoo east to find. Anyway on to the problem at hand, To make it answer after more rings there is switch on the back of the base. It hase 3 settings 3/5/TS. If set to 3 it will pick up in rings, set it to 5 and it will pick up in 5 rings. The TS setting stands for TollSaver, do not use this setting, TS will cause it to pick up in 2 rings. Set it to 5, however if you want to get 10rings before it picks up there's a little trick. When the answering machine gets full it will start picking up in 10rings, they do this so you know your answering machine is full. You can still leave a meassge even when it's full, it will automatically delete the oldest message to make room for a new one. However the display on the machin will display an F instead of the number of new messages. Well I hope the helps with that problem, because I hate to be the bearer of bad news but that phone has a maximum capability of 10 speed dials (0-9) and that's the max. There are models on the market with lots of speed dials but there usually corded phones. Well Good Luck & I hope this helps. L8R
Posted on Sep 17, 2007
  • 38 Answers
SOURCE: no dial tone
Have you tried a known good phone in the jack, if that doesn't work take the phone to the demarc box provided by your phone company and open the door on the box. Under this door locate the mini jack and disconnect it, then plug your known good phone into that jack. If you get no dial tone at this point, then it isn't being provided by the local phone company so it's their trouble. Thank you. Jerry
Posted on Feb 25, 2008
  • 319 Answers
SOURCE: Extra handsets no longer seem to work. No ring and no line
Please be sure to put the extra handsets in the MAIN base station to register. They will not register in the small remote charger stations.
Let me know if that fixes the problem!
Posted on Jun 17, 2008
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
  • 279 Answers
SOURCE: no dial tone/ cordless phone says "searching"
Go to They have the manual there
Posted on Sep 19, 2009
  • 8197 Answers
SOURCE: The ringer of the handset
There are two ways to set the ringer to HI/LOW/OFF. One is the traditional way as described in the Programming Functions; Handset Setup; Ringer Volume menus. The other one is this short cut to ringer menu.
1. Make sure the phone is OFF (not in talk mode).
2. Press the #PAUSE/RINGER button to display 1HI 2LOW 3OFF.
3. Use the touch tone pad on the handset to select 1, 2 or 3, or use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press #PAUSE/RINGER button again to save and display the new selection for a few seconds.
Or you can get the manual on the link below. It does not tell you how to rest the phone. If you can not read it on the top bar change the % to where you can read it.
Posted on Jan 10, 2011
0 characters
1 Points
My phone #1 does not ring nor can I get a dial tone.
Troubleshooting Home Phone for No Dial Tone ' iiHelp
This article will explain what to do if you can't make or receive calls using your HomePhone (landline). ... If it rings normally, skip to step 3. If you hear an engaged tone ora recorded voice saying the number is not available, ... If you have a dial tone and can make a call when your phone is plugged into one socket but not ...
No Dial Tone - Phone Forum - Phone Forum - Cox Support 1, 2014 - 16 posts - ‎13 authorsThis will help determine which phone or jack may be contributing to the problem. If these steps do not restore your phone service it may be necessary to ... directly to the #1 telephone port on the modem and see if you get dial tone there. ... Then try calling yourself(from a cell phone), and as it rings, plug the ...Big Mystery...Phone won't ring ' Techlore
Jan 10, 2016 | Phones
Phone doesn't ring, no dial tone.
Try switching the battery wilth a know to be
good battery
Dec 01, 2007 | Motorola Mobility MA 361 Cordless Phone
Why can't I rec or make calls?
What is happening when a call comes in are they getting a busy signal? If so your line is shorted out.. unplug all phones and see if caller hears a ring.. Then 1 at a time plug phones in. Check for a dial tone and press a digit, hang up and check and see if dial tone returns, repeat this on all phones, until you get to the phone that does not give you dial tone back after dialing a digit. That will be your bad phone... If the line was ring busy after all phones unplugged, call repair service..
Aug 10, 2015 | Phones
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Phones
Merlin BIS-10 no dial tone and can't answer but phone rings
I have a dial tone but can not make calls. and if the phone ring they can hear me but I cannot hear them
Apr 01, 2013 | Avaya MLS 12D Corded Phone
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
Phone has worked ok till saturday ,now no dial tone ,if i ring my phone with my mobile i can here it ringing but no sound coming from my phone , i plugged in another phone and still the same ,please help...
No dial tone on telephone set? could mean alot of things. Phone went bad, jack is bad(test in different jack or from a network interface, either inside or outside. depending what your dwelling is)
Just to point out a fact, when dial from your mobile to that number that has no dialtone, that ringing sound you hear is from the central office that is putting out that ringing, it has nothing to do with the phone you're trying to ring to. You would hear the ringing sound, even if all your phones were unplugged from every jack in your dwelling.
Oct 25, 2010 | Phones
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
My phone doesn't ring! When I phone my house from say a mobile, it seems to be ringing ok but there's no ring coming from any phone??I have taken every phone out of the sockets, taken out the broadband...
please try different phones one by one while you are confirmed that ringer in high in all phones if you got no ring you must call phone company.
Jul 23, 2008 | Phones
GE 27938GE1 Cordless Phone (01-27938ge1) Logo
20 people viewed this question
Top GE Phones Experts
Are you a GE Phone Expert? Answer questions, earn points and help others
