Question about RIM BlackBerry Pearl Smartphone
I hate this Phone
I cant send messages or answer any calls with my at&t phone because, when I press the send button letters come up its like my send key is locked and when i use my track ball it cant click on anything either how can i fix it??
  • jlocher02 Feb 04, 2009
    I can scroll but the push button portion of the roller ball stopped working
  • 2,794 Answers
There are replacement track balls available.
Here is a link to one:
http://www.blackberrytrackballs.com/?GoogPearl1&gclid=CLqh0cL3zZcCFQMCagod6yVMCg
Posted on Dec 20, 2008
Voicemail button redirected to phone line
If, perhaps you mean "it rings another one of our..." Phone Extensions, then just press the illuminated red message button, go to the ringing phone (the extension number will appear on your phone if you have a display phone) and answer the call by lifting the phone off-hook, then hang it up. Now the message button on your phone will work normally. What happened was that the user of the phone that was ringing when you pressed the button had inadvertently left you a "message waiting" after they called your phone on the intercom. By pressing the message button on your phone, you returned their call, and by answering the return call, you cleared the message waiting indication on your phone. There can be more than one message waiting, so if the light is still on after you clear the first call, using the procedure above, do it again and again until each call is returned, answered and cleared.
Mar 04, 2015 | Panasonic KXDT343 Phone
I cant recieve calls or make any calls from my cell phone
Hello:
You need to restore factory settings of your k800i .
your phone default code is 0000, go to setting then select restore setting or factory setting and enter code 0000 .
If this solution is helpful please click a thumbs-up rating below.
good luck .
Feb 03, 2010 | Samsung Cell Phones
I have a brand new g1 only 4 days old, and every time im on the web and I use the physical keyboard it wont let me type certain letters and words. Like I type the letter "V" and it types "r o i" evertime....
yes if u have phone isnurance send it in for a fix if not call and have it placed upon your phone call them back and then telll them the problem and send it in for a free fix
Dec 29, 2009 | HTC G1
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
Cant turn auto answer off; no general option icon in my options
on your phone press the green send button once. that will bring up your call log. then press the menu button and that will bring up a new screen. scroll down until you find the options and select it. it will then bring up the phone options menu. selct general options and then you will be able to change you answer options
Mar 27, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Blackberry 7100g
    About fixed dialing
    If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
    so if you have this enabled chances are you have to turn it off.
    this is how you turn it on so you should be able to use it as a guide to turn it off.
    Turn on fixed dialing
    1. In the phone options, click FDN Phone List.
    2. Click the trackwheel.
    3. Click Enable FDN mode.
    4. Type the PIN2 code provided by your service provider.
    5. Click the trackwheel.
    or if you wanna keep it on and add friends to the fdn
    Add contacts to the FDN list
    3. Click New.
    6. Type a name and a phone number.
    7. Click the trackwheel.
    8. Click Save.
    and finally some shortcut keys:
    To open the phone, press the Send key.
    To end a call, press the End key.
    To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
    To add an extension to a phone number, press the X key. Type the extension number.
    To call your voice mail access number, hold 1.
    To type a letter in a number field, hold the Alt key.
    To type the first letter on a key, press the letter key once.
    To type the second letter on a key, press the letter key twice.
    To turn on or turn off mute using the Mute button, press the Mute button.
    To turn on or turn off mute using the keypad, press the exclamation point (!) key.
    To turn speakerphone on and off during a call, press the period (.) key.
    To change the volume during a call, roll the trackwheel.
    Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
    When simeone calls, it won't record their message
    Try this..
    Press "menu" button until you hear  "Change Announce only" Press "select" button until you hear  "off" Press "Time/Set" button
    Apr 20, 2007 | AT&T 9353 Cordless Phone
    RIM BlackBerry Pearl Smartphone Logo
    64 people viewed this question
    Top RIM Computers & Internet Experts
    ismael castillo
    David
    Jerry Greenberg
    Jerry Greenberg
    Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
