Question about LG WD-3243RHD Front Load Washer / Dryer
I'm a service tech and registered with lg.ihave adle5977b front load drier tech support stated to me if 115volt at drier motor is read needs new motor i ordered new motor with same results.no motor action,what's up.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    First off, do you have 240 volts from L1 to L2?
    Problem Solver:
  • 16 Answers
Drier's are usually 240 volts.
Posted on Jul 02, 2009
Zanussi TC485W condenser tumble drier trips fuse when switched on
I had the same problem when I moved into my new house and upgraded the dryer. Its most likely the ground wire. Best to get a multimeter and test everything. If your not able to do that. You should call an electrician and have him check the wiring. Where he may need to run a new ground to your fuse box.
thanks,
Nathan
Jun 15, 2008 | Zanussi Dryers
I have an LG-WM2032HS front load clothes washing machine. Lately, I will put the clothes in, push speed cycle, or any other cycle and it will run it thru the soap, but when it comes to spinning it, it...
Sounds like all you need is a new pump motor. Pretty common issue. Fairly inexpensive motor. About $30+ on amazon. Check out repairclinic.com or appliancepartspros.com for part numbers and repair videos. Good luck.
Apr 30, 2017 | LG WM-2032H Front Load Washer
LG front load washer
That's actually DE (Drain Error). Clean out the filter behind the small access door on the front lower left side of the machine. The small hose is there to drain the water out first. If there is nothing in the filter, you may need a new pump motor. (pump impeller comes off shaft sometimes, requiring pump motor replacement)
May 06, 2010 | LG WM-2277HW Front Load Washer
Whirpool Duet Washing machine F-11 error
I purchased a Whirpool duel washing machine Aug 05. In June of 08 it showed an F11 error. After factory repair service tech. looked at it he said that i needed a main motor at a cost of $400.00 After search on internet many people reported problems also and decided not to repair it. Has any one had problems with theirs?Ihave the same problem is there any solution????please help
Jan 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG Tromm has the error code LE what is it?
unplug the machine or turn power to outlet off. wait five minutes. turn all back on should solve problem
Mar 15, 2009 | LG WM-2277HW Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Nov 18, 2007 | LG DLE2532W Electric Dryer
Not enough water
the timer motor is what is called a hysteresis synchronous motor. it runs off 120 volts and synchronizes itself with the frequency of 60 cycles which is what your power co is feeding to you. with your power going on and off and on and off, it created spikes on your house circuit which probably burnt out part of the timer motor. replacing just the timer motor should take care of the problem. the whole timer costs a lot of money like around $130. If yours is a solid state timer, there's no motor just a preprogrammed computer for fill, agitate, drain, rinse and spin. I have no idea what a new board costs but try parts select dot com. they have parts for major appliances.
Aug 26, 2007 | LG WM2487H Front Load Washer
LG WD-3243RHD Front Load Washer / Dryer Logo
114 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
